Item Part No. Description Book Engine 010001 Crankcase 100k0576010002 Oil Pan 100k0576010003 Cylinder Head 100k0576010004 Gear Case 100k0576010005 Head Cover 100k0576010100 Main Bearing Case 100k0576010101 Camshaft And Idle Gear Shaft 100k0576010102 Piston And Crankshaft 100k0576010103 Flywheel 100k0576010105 Fuel Camshaft 100k0576010200 Engine Stop Lever 100k0576010202 Injection Pump 100k0576010203 Injection Pump [component Parts] 100k0576010204 Governor 100k0576010205 Speed Control Plate 100k0576010206 Nozzle Holder And Glow Plug 100k0576010207 Nozzle Holder [component Parts] 100k0576010500 Water Flange And Thermostat 100k0576010501 Water Pump 100k0576010600 Valve And Rocker Arm 100k0576010601 Inlet Manifold 100k0576010906 Upper Gasket Kit 100k0576010907 Lower Gasket Kit 100k0576010602 Exhaust Manifold 100k0576010603 Air Cleaner 100k0576010604 Air Cleaner [component Parts] 100k057601060701 Muffler 100k057601a010 Hand Accelerator Lever 100k057601a070 Stop Solenoid/engine Stop Wire 100k0576fuel System 01a110 Fuel Tank 100k057601a170 Fuel Filter 100k057601a180 Fuel Filter [component Parts] 100k0576cooling System 01a410 Fan 100k057601a420 Water Pipe 100k057601a430 Radiator 100k057601a450 Reserve Tank 100k0576electrical System 01a540 Alternator 100k057601a550 Alternator [component Parts] 100k057601a560 Starter 100k057601a570 Starter [component Parts] 100k057601a580 Battery 100k057601b015 Switch/sensor 100k057601b106 Switch(Panel Board)/relay 100k057601b140 Panel Board 100k057601b150 Panel Board [component Parts] 100k057601b320 Light 100k057601b335 Hazard Light/tail Light [old Type] 100k057601b33501 Hazard Light/tail Light [new Type] 100k057601b515 Electrical Wiring 100k0576transmission/clutch/rear Axle 01c11001 Clutch Housing 100k057601c113 Shuttle Gear Case 100k057601c140 Transmission Case 100k057601c150 Transmission Case Rear Cover 100k057601c170 Rear Axle Case 100k057601c210 Clutch 100k057601c230 Clutch Release Fork 100k057601c240 Clutch Pedal 100k0576
