Item Part No. Description Book Engine 010001 Crank Case 100a0081010002 Oil Pan 100a0081010003 Cylinder Head 100a0081010004 Gear Case 100a0081010005 Head Cover 100a0081010100 Main Bearing Case 100a0081010101 Camshaft And Idle Gear Shaft 100a0081010102 Piston And Crank Shaft 100a0081010103 Flywheel 100a0081010105 Fuel Camshaft And Governor Shaft 100a0081010201 Stop Solenoid 100a0081010202 Injection Pump 100a0081010203 Injection Pump [component Parts] 100a0081010204 Governor 100a0081010205 Speed Control Plate 100a0081010206 Nozzle Holder And Glow Plug 100a0081010207 Nozzle Holder [component Parts] 100a0081010500 Water Flange And Thermostat 100a0081010501 Water Pump 100a0081010600 Valve And Rocker Arm 100a0081010601 Inlet Manifold 100a0081010602 Exhaust Manifold 100a008101090001 Upper Gasket Kit 100a008101090002 Lower Gasket Kit 100a0081electrical System 01a521 Dynamo 100a008101a523 Dynamo [component Parts] 100a0081clutch 01c101 Clutch 100a0081hydraulic System 01j120 Hydraulic Pump 100a008101j125 Hydraulic Pump [component Parts] 100a0081engine 02060301 Air Cleaner 100a008102060302 Air Cleaner 100a008102060303 Air Cleaner (Double) [option] 100a0081020605 Muffler 100a0081fuel System 02a001 Accelerator Lever 100a008102a101 Fuel Tank 100a008102a110 Fuel Pipe 100a008102a130 Fuel Filter [component Parts] 100a0081cooling Water System 02a401 Fan 100a008102a410 Water Pipe 100a008102a420 Radiator 100a0081electrical System 02a515 Alternator [ca] 100a008102a520 Alternator [component Parts] [ca] 100a008102a525 Starter 100a008102a530 Starter [component Parts] 100a008102a535 Battery 100a008102b115 Panel Board 100a008102b120 Panel Board [component Parts] 100a008102b301 Head Light 100a008102b302 Tail Light/hazard Light/working Light 100a008102b50101 Electrical Wiring 100a008102b50102 Electrical Wiring [ca] 100a0081clutch 02c110 Clutch Rod 100a008102c301 Clutch Pedal 100a008102c401 Clutch Housing 100a0081frame 02c415 Frame 100a0081transmission 02c420 Transmission Case 100a008102c425 Differential Gear Case 100a008102c427 Rear Axle Case 100a008102d001 Clutch Shaft/proreller Shaft 100a008102d010 Hst 100a0081
