Item Part No. Description Book Engine 010001 Crankcase 100k0615010002 Oil Pan 100k0615010003 Cylinder Head 100k0615010004 Gear Case 100k0615010005 Head Cover 100k0615010100 Main Bearing Case 100k0615010101 Camshaft And Idle Gear Shaft 100k0615010102 Piston And Crank Shaft 100k0615010103 Flywheel 100k0615010105 Fuel Camshaft And Governor Shaft 100k0615010201 Stop Solenoid 100k0615010202 Injection Pump 100k0615010203 Injection Pump [component Parts] 100k0615010204 Governor 100k0615010205 Speed Control Plate 100k0615010206 Nozzle Holder And Glow Plug 100k0615010207 Nozzle Holder [component Parts] 100k0615010500 Water Flange And Thermostat 100k0615010501 Water Pump 100k0615010600 Valve And Rocker Arm 100k0615010601 Inlet Manifold 100k0615010602 Exhaust Manifold 100k061501090001 Upper Gasket Kit 100k061501090002 Lower Gasket Kit 100k0615electrical System 01a521 Dynamo 100k061501a523 Dynamo [component Parts] 100k0615clutch 01c101 Clutch 100k0615hydraulic System 01j120 Hydraulic Pump 100k061501j125 Hydraulic Pump [component Parts] 100k0615engine 02060301 Air Cleaner 100k061502060302 Air Cleaner 100k061502060303 Air Cleaner(Double) [option] 100k0615020605 Muffler 100k0615fuel System 02a001 Accelerator Lever 100k061502a101 Fuel Tank 100k061502a110 Fuel Pipe 100k061502a11001 Fuel Pipe 100k061502a130 Fuel Filter [component Parts] 100k0615cooling Water System 02a401 Fan 100k061502a410 Water Pipe 100k061502a420 Radiator 100k0615electrical System 02a515 Alternator [ca] 100k061502a520 Alternator [component Parts] [ca] 100k061502a525 Starter 100k061502a530 Starter [component Parts] 100k061502a535 Battery 100k061502b115 Panel Board 100k061502b120 Panel Board [component Parts] 100k061502b301 Head Light 100k061502b302 Tail Light/hazard Light/working Light 100k061502b50101 Electrical Wiring 100k061502b50102 Electrical Wiring [ca] 100k0615clutch 02c110 Clutch Rod 100k061502c301 Clutch Pedal 100k061502c401 Clutch Housing 100k0615frame 02c415 Frame 100k0615transmission 02c420 Transmission Case 100k0615
