Item Part No. Description Book Engine 010001 Crankcase 100k0618010002 Oil Pan 100k0618010003 Cylinder Head 100k0618010004 Gear Case 100k0618010005 Head Cover 100k0618010100 Main Bearing Case 100k0618010101 Camshaft And Idle Gear Shaft 100k0618010102 Piston And Crank Shaft 100k0618010103 Flywheel 100k0618010105 Fuel Camshaft And Governor Shaft 100k0618010201 Stop Solenoid 100k0618010202 Injection Pump 100k0618010204 Governor 100k0618010205 Speed Control Plate 100k0618010206 Nozzle Holder And Glow Plug 100k0618010207 Nozzle Holder [component Parts] 100k0618010500 Water Flange And Thermostat 100k0618010501 Water Pump 100k0618010600 Valve And Rocker Arm 100k0618010601 Inlet Manifold 100k0618010602 Exhaust Manifold 100k061802060302 Air Cleaner 100k061802060303 Air Cleaner (Double) [option] 100k0618020605 Muffler 100k061801090001 Upper Gasket Kit 100k061801090002 Lower Gasket Kit 100k061801090003 Lower Gasket Kit 100k0618fuel System 02a001 Accelerator Lever 100k061802a101 Fuel Tank 100k061802a11001 Fuel Pipe 100k061802a130 Fuel Filter [component Parts] 100k0618cooling Water System 02a401 Fan 100k061802a410 Water Pipe 100k061802a420 Radiator 100k0618electrical System 02a515 Alternator [ca] 100k061802a520 Alternator [component Parts] [ca] 100k061801a521 Dynamo 100k061801a523 Dynamo [component Parts] 100k061802a525 Starter 100k061802a530 Starter [component Parts] 100k061802a535 Battery 100k061802b115 Panel Board 100k061802b120 Panel Board [component Parts] 100k061802b301 Head Light 100k061802b302 Tail Light/hazard Light/working Light 100k061802b50101 Electrical Wiring 100k061802b50102 Electrical Wiring [ca] 100k0618clutch 01c101 Clutch 100k061802c110 Clutch Rod 100k061802c301 Clutch Pedal 100k061802c401 Clutch Housing 100k0618frame 02c415 Frame 100k0618transmission 02c420 Transmission Case 100k061802c425 Differential Gear Case 100k061802c427 Rear Axle Case 100k061802d001 Clutch Shaft/propeller Shaft 100k061802d105 2nd Shaft/3rd Shaft/4th Shaft 100k061802d135 5th Shaft/pto Shaft 100k061802d137 Mid Pto 100k0618
