Item Part No. Description Book Engine 010001 Crank Case 100a0078010002 Oil Pan 100a0078010003 Cylinder Head 100a0078010004 Gear Case 100a0078010005 Head Cover 100a0078010100 Main Bearing Case 100a0078010101 Camshaft And Idle Gear Shaft 100a0078010102 Piston And Crank Shaft 100a0078010103 Flywheel 100a0078010105 Fuel Camshaft And Governor Shaft 100a0078010201 Stop Solenoid 100a0078010202 Injection Pump 100a0078010203 Injection Pump [component Parts] 100a0078010204 Governor 100a0078010205 Speed Control Plate 100a0078010206 Nozzle Holder And Glow Plug 100a0078010207 Nozzle Holder [component Parts] 100a0078010500 Water Flange And Thermostat 100a0078010501 Water Pump 100a0078010600 Valve And Rocker Arm 100a0078010601 Inlet Manifold 100a0078010602 Exhaust Manifold 100a007801090001 Upper Gasket Kit 100a007801090002 Lower Gasket Kit 100a0078electrical System 01a521 Dynamo 100a007801a523 Dynamo [component Parts] 100a0078clutch 01c101 Clutch 100a0078hydraulic System 01j120 Hydraulic Pump 100a007801j125 Hydraulic Pump [component Parts] 100a0078engine 02060301 Air Cleaner 100a007802060302 Air Cleaner 100a007802060303 Air Cleaner (Double) [option] 100a0078020605 Muffler 100a0078fuel System 02a001 Accelerator Lever 100a007802a101 Fuel Tank 100a007802a110 Fuel Pipe 100a007802a11001 Fuel Pipe 100a007802a130 Fuel Filter [component Parts] 100a0078cooling Water System 02a401 Fan 100a007802a410 Water Pipe 100a007802a420 Radiator 100a0078electrical System 02a515 Alternator [ca] 100a007802a520 Alternator [component Parts] [ca] 100a007802a525 Starter 100a007802a530 Starter [component Parts] 100a007802a535 Battery 100a007802b115 Panel Board 100a007802b120 Panel Board [component Parts] 100a007802b301 Head Light 100a007802b302 Tail Light/hazard Light/working Light 100a007802b50101 Electrical Wiring 100a007802b50102 Electrical Wiring [ca] 100a0078clutch 02c110 Clutch Rod 100a007802c301 Clutch Pedal 100a007802c401 Clutch Housing 100a0078frame 02c415 Frame 100a0078
