Item Part No. Description Book Engine 010001 Crankcase 100k0655010002 Oil Pan 100k0655010003 Cylinder Head 100k0655010004 Gear Case 100k0655010005 Head Cover 100k0655010100 Main Bearing Case 100k0655010101 Camshaft And Idle Gear Shaft 100k0655010102 Piston And Crankshaft 100k065501010302 Flywheel [4wd] 100k0655010105 Fuel Camshaft 100k0655010200 Engine Stop Lever 100k0655010202 Injection Pump 100k0655010204 Governor 100k0655010205 Speed Control Plate 100k0655010206 Nozzle Holder And Glow Plug 100k0655010207 Nozzle Holder [component Parts] 100k0655010500 Water Flange And Thermostat 100k0655010501 Water Pump 100k0655010600 Valve And Rocker Arm 100k0655010601 Inlet Manifold 100k0655010901 Upper Gasket Kit 100k0655010902 Lower Gasket Kit 100k0655010603 Exhaust Manifold/muffler 100k0655010604 Air Cleaner 100k065501a003 Engine Stop Rod 100k065501a010 Accelerator Lever 100k065501a025 Accelerator Linkage 100k0655fuel System 01a101 Fuel Tank 100k065501a110 Fuel Pipe And Fuel Filter 100k065501a130 Fuel Filter [component Parts] 100k0655cooling Water System 01a401 Fan 100k065501a410 Water Pipe 100k065501a420 Radiator 100k065501a430 Reserve Tank 100k0655electrical System 01a515 Alternator 100k065501a520 Alternator [component Parts] 100k065501a525 Starter 100k065501a530 Starter [component Parts] 100k065501a535 Battery 100k065501b102 Switch 1 100k065501b103 Switch 2 100k065501b115 Panel Board 100k065501b120 Panel Board [component Parts] 100k065501b301 Light 100k065501b501 Electrical Wiring 100k0655transmission/clutch/rear Axle 01c101 Clutch 100k065501c201 Clutch Lever 100k065501c301 Clutch Pedal 100k065501c40101 Clutch Housing 100k065501c410 Mid Case 100k065501c42001 Transmission Case 100k065501d101 Main Shaft 100k065501d105 Countershaft 100k065501d116 Reverse Shaft 100k065501d117 Range Gear Shaft 100k065501d12501 Spiral Bevel Pinion 100k065501d127 Rear Differential 100k0655
