Item Part No. Description Book Engine 010001 Crankcase 100k0570010002 Oil Pan 100k0570010003 Cylinder Head 100k0570010004 Gear Case 100k0570010005 Head Cover 100k0570010100 Main Bearing Case 100k0570010101 Camshaft And Idle Gear Shaft 100k0570010102 Piston And Crankshaft 100k057001010301 Flywheel 100k057001010502 Fuel Camshaft 100k0570010200 Engine Stop Lever 100k057001020201 Injection Pump 100k0570010203 Injection Pump [component Parts] 100k0570010204 Governor 100k0570010205 Speed Control Plate 100k0570010206 Nozzle Holder And Glow Plug 100k0570010207 Nozzle Holder [component Parts] 100k0570010500 Water Flange And Thermostat 100k0570010501 Water Pump 100k0570010600 Valve And Rocker Arm 100k0570010601 Inlet Manifold 100k0570010602 Exhaust Manifold 100k057001090101 Upper Gasket Kit 100k057001090201 Lower Gasket Kit 100k0570010604 Air Cleaner 100k0570010606 Muffler 100k057001a003 Engine Stop Rod 100k057001a01001 Accelerator Lever 100k057001a025 Accelerator Linkage 100k0570fuel System 01a101 Fuel Tank 100k057001a11001 Fuel Pipe And Fuel Filter 100k057001a130 Fuel Filter [component Parts] 100k0570cooling Water System 01a401 Fan 100k057001a410 Water Pipe 100k057001a420 Radiator 100k0570electrical System 01a51501 Alternator 100k057001a520 Alternator [component Parts] 100k057001a525 Starter 100k057001a530 Starter [component Parts] 100k057001a535 Battery 100k057001b102 Switch 1 100k057001b10301 Switch 2 100k057001b115 Panel Board 100k057001b120 Panel Board [component Parts] 100k057001b301 Light 100k057001b50102 Electrical Wiring 100k0570transmission/clutch/rear Axle 01c10101 Clutch 100k057001c20101 Clutch Lever 100k057001c30101 Clutch Pedal 100k057001c40101 Clutch Housing 100k057001c42002 Transmission Case 100k057001d10101 Main Shaft 100k057001d10501 Countershaft 100k057001d116 Reverse Shaft 100k057001d117 Range Gear Shaft 100k057001d12502 Spiral Bevel Pinion 100k057001d12701 Rear Differential 100k057001d13002 Pto Countershaft 100k057001d135 Pto Shaft 100k057001d20101 Main Gear Shift Fork 100k0570
