Item Part No. Description Bookengine 010001 Crankcase 100k0569010002 Oil Pan 100k0569010003 Cylinder Head 100k0569010004 Gear Case 100k0569010005 Head Cover 100k0569010100 Main Bearing Case 100k0569010101 Camshaft And Idle Gear Shaft 100k0569010102 Piston And Crankshaft 100k056901010301 Flywheel 100k056901010501 Fuel Camshaft 100k0569010200 Engine Stop Lever 100k056901020201 Injection Pump 100k0569010203 Injection Pump [component Parts] 100k0569010204 Governor 100k0569010205 Speed Control Plate 100k0569010206 Nozzle Holder And Glow Plug 100k0569010207 Nozzle Holder [component Parts] 100k0569010500 Water Flange And Thermostat 100k0569010501 Water Pump 100k0569010600 Valve And Rocker Arm 100k0569010601 Inlet Manifold 100k0569010602 Exhaust Manifold 100k056901090101 Upper Gasket Kit 100k056901090201 Lower Gasket Kit 100k0569010604 Air Cleaner 100k0569010606 Muffler 100k056901a003 Engine Stop Rod 100k056901a01001 Accelerator Lever [old Type] 100k056901a01002 Accelerator Lever [new Type] 100k056901a025 Accelerator Linkage 100k0569fuel System 01a101 Fuel Tank 100k056901a11001 Fuel Pipe And Fuel Filter 100k056901a130 Fuel Filter [component Parts] 100k0569cooling Water System 01a401 Fan 100k056901a410 Water Pipe 100k056901a420 Radiator 100k0569electrical System 01a51501 Alternator 100k056901a520 Alternator [component Parts] 100k056901a525 Starter 100k056901a530 Starter [component Parts] 100k056901a535 Battery 100k056901b102 Switch 1 100k056901b10301 Switch 2 100k056901b115 Panel Board 100k056901b120 Panel Board [component Parts] 100k056901b301 Light [old Type] 100k056901b30101 Light [new Type] 100k056901b50101 Electrical Wiring 100k0569transmission/clutch/rear Axle 01c10101 Clutch 100k056901c20101 Clutch Lever 100k056901c30101 Clutch Pedal [old Type] 100k056901c30102 Clutch Pedal [new Type] 100k056901c40101 Clutch Housing 100k056901c42001 Transmission Case 100k056901d10101 Main Shaft 100k056901d10501 Countershaft 100k056901d116 Reverse Shaft 100k056901d117 Range Gear Shaft 100k056901d12501 Spiral Bevel Pinion 100k0569
