Kubota L3000F Instructions for Parts Books - Instruction Manual
Item Part No. Description Book engine 01000101 Crankcase 100k0571010002 Oil Pan 100k0571010003 Cylinder Head 100k0571010004 Gear Case 100k0571010005 Head Cover 100k0571010100 Main Bearing Case 100k0571010101 Camshaft And Idle Gear Shaft 100k0571010102 Piston And Crankshaft 100k057101010302 Flywheel 100k057101010502 Fuel Camshaft 100k0571010200 Engine Stop Lever 100k057101020202 Injection Pump 100k0571010203 Injection Pump [component Parts] 100k0571010204 Governor 100k0571010205 Speed Control Plate 100k0571010206 Nozzle Holder And Glow Plug 100k0571010207 Nozzle Holder [component Parts] 100k0571010500 Water Flange And Thermostat 100k0571010501 Water Pump 100k0571010600 Valve And Rocker Arm 100k0571010601 Inlet Manifold 100k0571010602 Exhaust Manifold 100k057101090102 Upper Gasket Kit 100k057101090202 Lower Gasket Kit 100k0571010604 Air Cleaner 100k0571010606 Muffler 100k057101a003 Engine Stop Rod 100k057101a01003 Accelerator Lever [old Type] 100k057101a01004 Accelerator Lever [new Type] 100k057101a025 Accelerator Linkage 100k0571fuel System 01a101 Fuel Tank 100k057101a11002 Fuel Pipe And Fuel Filter 100k057101a130 Fuel Filter [component Parts] 100k0571cooling Water System 01a401 Fan 100k057101a410 Water Pipe 100k057101a420 Radiator 100k0571electrical System 01a51502 Alternator 100k057101a520 Alternator [component Parts] 100k057101a525 Starter 100k057101a530 Starter [component Parts] 100k057101a535 Battery 100k057101b102 Switch 1 100k057101b10302 Switch 2 100k057101b115 Panel Board 100k057101b120 Panel Board [component Parts] 100k057101b301 Light [old Type] 100k057101b30101 Light [new Type] 100k057101b50103 Electrical Wiring 100k0571transmission/clutch/rear Axle 01c10102 Clutch 100k057101c20102 Clutch Lever 100k057101c30103 Clutch Pedal 100k057101c40102 Clutch Housing 100k057101c42001 Transmission Case 100k057101d10102 Main Shaft 100k057101d10502 Countershaft 100k057101d116 Reverse Shaft 100k057101d117 Range Gear Shaft 100k0571​
