Kubota MX5000DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 010001 Crankcase 100k0680010002 Oil Pan 100k0680010003 Cylinder Head 100k0680010004 Gear Case 100k0680010005 Head Cover 100k0680010100 Main Bearing Case 100k0680010101 Camshaft And Idle Gear Shaft 100k0680010102 Piston And Crankshaft 100k068001010302 Flywheel 100k0680010105 Fuel Camshaft 100k0680010106 Balancer 100k0680010200 Engine Stop Lever 100k0680010202 Injection Pump 100k0680010203 Injection Pump [componentparts]100k0680010204 Governor 100k0680010205 Speed Control Plate 100k0680010206 Nozzle Holder And Glow Plug 100k0680010207 Nozzle Holder [componentparts]100k0680010500 Water Flange And Thermostat 100k0680010501 Water Pump 100k0680010600 Valve And Rocker Arm 100k0680010601 Inlet Manifold 100k0680010901 Upper Gasket Kit 100k0680010902 Lower Gasket Kit 100k0680010603 Exhaust Manifold/muffler 100k0680010604 Air Cleaner 100k068001a004 Engine Stop Wire 100k068001a010 Accelerator Lever 100k068001a025 Accelerator Linkage 100k0680fuel System 01a101 Fuel Tank 100k068001a110 Fuel Pipe And Fuel Filter 100k068001a130 Fuel Filter [component Parts] 100k0680cooling Water System 01a401 Fan 100k068001a410 Water Pipe 100k068001a420 Radiator 100k068001a430 Reserve Tank 100k0680electrical System 01a515 Alternator 100k068001a520 Alternator [component Parts] 100k068001a525 Starter 100k068001a530 Starter [component Parts] 100k068001a535 Battery 100k068001b102 Switch 1 100k068001b103 Switch 2 100k068001b115 Panel Board 100k068001b120 Panel Board [component Parts] 100k068001b304 Light 1 100k068001b30501 Light 2 [old Type] 100k068001b30502 Light 2 [new Type] 100k068001b50101 Electrical Wiring [old Type] 100k068001b50102 Electrical Wiring [new Type] 100k0680transmission/clutch/rear Axle 01c101 Clutch 100k068001c201 Clutch Lever 100k068001c301 Clutch Pedal 100k068001c40102 Clutch Housing 100k0680​
