Item Part No. Description Book Engine 010001 Crankcase 100k0825010002 Oil Pan 100k0825010003 Cylinder Head 100k0825010004 Gear Case 100k0825010005 Head Cover 100k0825010100 Main Bearing Case 100k0825010101 Camshaft And Idle Gear Shaft 100k0825010102 Piston And Crankshaft 100k082501010302 Flywheel 100k0825010105 Fuel Camshaft 100k0825010200 Engine Stop Lever 100k0825010202 Injection Pump 100k0825010204 Governor 100k0825010205 Speed Control Plate 100k0825010206 Nozzle Holder And Glow Plug 100k0825010207 Nozzle Holder [componentparts]100k0825010500 Water Flange And Thermostat 100k0825010501 Water Pump 100k0825010600 Valve And Rocker Arm 100k0825010601 Inlet Manifold 100k0825010603 Exhaust Manifold/muffler 100k0825010604 Air Cleaner 100k0825010901 Upper Gasket Kit 100k0825010902 Lower Gasket Kit 100k082501a010 Accelerator Lever 100k082501a025 Accelerator Linkage 100k0825fuel System 01a101 Fuel Tank 100k082501a110 Fuel Pipe And Fuel Filter 100k082501a130 Fuel Filter [component Parts] 100k0825cooling Water System 01a401 Fan 100k082501a410 Water Pipe 100k082501a420 Radiator 100k082501a430 Reserve Tank 100k0825electrical System 01a515 Alternator 100k082501a520 Alternator [component Parts] 100k082501a525 Starter 100k082501a530 Starter [component Parts] 100k082501a535 Battery 100k082501b102 Switch 1 / Relay 100k082501b103 Switch 2 / Sensor 100k082501b115 Panel Board 100k082501b120 Panel Board [component Parts] 100k082501b30301 Head Light [old Type] 100k082501b30302 Head Light [new Type] 100k082501b311 Hazard Light 100k082501b312 Rear Lamp 100k082501b501 Electrical Wiring 100k0825clutch/transmission 01c101 Clutch 100k082501c201 Clutch Lever 100k082501c301 Clutch Pedal 100k082501c40102 Clutch Housing 100k0825
