Kubota MX5000F Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 010001 Crankcase 100k0681010002 Oil Pan 100k0681010003 Cylinder Head 100k0681010004 Gear Case 100k0681010005 Head Cover 100k0681010100 Main Bearing Case 100k0681010101 Camshaft And Idle Gear Shaft 100k0681010102 Piston And Crankshaft 100k068101010302 Flywheel 100k0681010105 Fuel Camshaft 100k0681010106 Balancer 100k0681010200 Engine Stop Lever 100k0681010202 Injection Pump 100k0681010203 Injection Pump [component Parts] 100k0681010204 Governor 100k0681010205 Speed Control Plate 100k0681010206 Nozzle Holder And Glow Plug 100k0681010207 Nozzle Holder [component Parts] 100k0681010500 Water Flange And Thermostat 100k0681010501 Water Pump 100k0681010600 Valve And Rocker Arm 100k0681010601 Inlet Manifold 100k0681010901 Upper Gasket Kit 100k0681010902 Lower Gasket Kit 100k0681010603 Exhaust Manifold/muffler 100k0681010604 Air Cleaner 100k068101a004 Engine Stop Wire 100k068101a010 Accelerator Lever 100k068101a025 Accelerator Linkage 100k0681fuel System 01a101 Fuel Tank 100k068101a110 Fuel Pipe And Fuel Filter 100k068101a130 Fuel Filter [component Parts] 100k0681cooling Water System 01a401 Fan 100k068101a410 Water Pipe 100k068101a420 Radiator 100k068101a430 Reserve Tank 100k0681electrical System 01a515 Alternator 100k068101a520 Alternator [component Parts] 100k068101a525 Starter 100k068101a530 Starter [component Parts] 100k068101a535 Battery 100k068101b102 Switch 1 100k068101b103 Switch 2 100k068101b115 Panel Board 100k068101b120 Panel Board [component Parts] 100k068101b304 Light 1 100k068101b30501 Light 2 [old Type] 100k068101b30502 Light 2 [new Type] 100k068101b50101 Electrical Wiring [old Type] 100k068101b50102 Electrical Wiring [new Type] 100k0681transmission/clutch/rear Axle 01c101 Clutch 100k068101c201 Clutch Lever 100k068101c301 Clutch Pedal 100k068101c40101 Clutch Housing 100k068101c410 Mid Case 100k068101c42001 Transmission Case 100k068101d101 Main Shaft 100k068101d105 Countershaft 100k068101d117 Range Gear Shaft 100k068101d12501 Spiral Bevel Pinion 100k0681​
