Kubota L3450DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k001801t002 Oil Pan 100k001801t003 Piston And Crankshaft 100k001801t004 Main Bearing Case 100k001801t00501 Flywheel [with Dual Clutch] 100k001801t006 Cylinder Head 100k001801t007 Valve And Rocker Arm 100k001801t008 Nozzle And Glow Plug 100k001801t009 Cylinder Head Cover 100k001801t010 Inlet Manifold 100k001801t014 Camshaft 100k001801t015 Gear Case 100k001801t016 Water Pump 100k001801t017 Water Flange And Thermostat 100k001801t018 Fuel Camshaft 100k001801t019 Injection Pump 100k001801t020 Injection Pump [component Parts] 100k001801t021 Engine Stop Lever 100k001801t022 Speed Control Plate 100k001801t023 Governor 100k001801t01101 Air Cleaner 100k001801t01102 Double Air Cleaner [option] 100k001801t012 Pre-cleaner [option] 100k001801t01301 Exhaust Manifold And Muffler 100k001801t01302 Under Muffler [option] 100k001801t024 Stop Rod 100k001801t02501 Accelerator Lever 100k001801t02502 Accelerator Lever [hydrostatic Ps] 100k001801t026 Accelerator Linkage 100k0018fuel System 01t027 Fuel Tank 100k001801t028 Fuel Filter 100k001801t029 Fuel Filter [component Parts] 100k0018cooling Water System 01t03001 Fan [old Type] 100k001801t03002 Fan [new Type] 100k001801t031 Water Pipe 100k001801t032 Radiator 100k001801t033 Reserve Tank 100k001801t034 Shutter 100k0018electrical System 01t03501 Dynamo [a] 100k001801t03601 Dynamo [component Parts] [a] 100k001801t037 Starter 100k001801t038 Starter [component Parts] 100k001801t039 Battery 100k001801t040 Switch 100k001801t041 Panel 100k001801t042 Light 100k001801t04301 Electrical Wiring [a] 100k0018clutch 01t04401 Clutch [dual Clutch] 100k001801t04501 Clutch Lever [with Dual Clutch] 100k001801t04601 Clutch Pedal [with Dual Clutch] 100k001801t04701 Clutch Housing [with Dual Clutch] 100k0018transmission 01t048 Transmission Case 100k001801t04901 Main Shaft [with Dual Clutch] 100k001801t05001 Countershaft 1 [constant Mesh] 100k001801t05002 Countershaft 1 [synchro Mesh] 100k001801t051 Countershaft 2 100k0018​
