Kubota L2650F Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k002701t002 Oil Pan 100k002701t003 Piston And Crankshaft 100k002701t004 Main Bearing Case 100k002701t00501 Flywheel [with Dual Clutch] 100k002701t006 Cylinder Head 100k002701t007 Valve And Rocker Arm 100k002701t008 Nozzle And Glow Plug 100k002701t009 Cylinder Head Cover 100k002701t010 Inlet Manifold 100k002701t014 Camshaft 100k002701t015 Gear Case 100k002701t016 Water Pump 100k002701t017 Water Flange And Thermostat 100k002701t018 Fuel Camshaft 100k002701t019 Injection Pump 100k002701t020 Injection Pump [component Parts] 100k002701t021 Engine Stop Lever 100k002701t022 Speed Control Plate 100k002701t023 Governor 100k002701t01101 Air Cleaner 100k002701t01102 Double Air Cleaner [option] 100k002701t012 Pre-cleaner [option] 100k002701t01301 Exhaust Manifold And Muffler 100k002701t01302 Under Muffler [option] 100k002701t024 Stop Rod 100k002701t02501 Accelerator Lever 100k002701t026 Accelerator Linkage 100k0027fuel System 01t027 Fuel Tank 100k002701t028 Fuel Filter 100k002701t029 Fuel Filter [component Parts] 100k0027cooling Water System 01t03002 Fan [new Type] 100k002701t031 Water Pipe 100k002701t032 Radiator 100k002701t033 Reserve Tank 100k002701t034 Shutter 100k0027electrical System 01t03501 Dynamo [a] 100k002701t03601 Dynamo [component Parts] [a] 100k002701t037 Starter 100k002701t03802 Starter [component Parts] 100k002701t039 Battery 100k002701t040 Switch 100k002701t041 Panel 100k002701t042 Light 100k002701t04301 Electrical Wiring [a] 100k0027clutch 01t04401 Clutch [dual Clutch] 100k002701t04501 Clutch Lever [with Dual Clutch] 100k002701t04601 Clutch Pedal [with Dual Clutch] 100k002701t04701 Clutch Housing [with Dual Clutch] 100k0027transmission 01t048 Transmission Case 100k002701t04901 Main Shaft [with Dual Clutch] 100k002701t05001 Countershaft 1 [constant Mesh] 100k002701t05002 Countershaft 1 [synchro Mesh] 100k002701t051 Countershaft 2 100k002701t052 Pto Countershaft 1 [with Dual Clutch]​
