Kubota L2950DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k002801t002 Oil Pan 100k002801t003 Piston And Crankshaft 100k002801t004 Main Bearing Case 100k002801t00501 Flywheel [with Dual Clutch] 100k002801t006 Cylinder Head 100k002801t007 Valve And Rocker Arm 100k002801t008 Nozzle And Glow Plug 100k002801t009 Cylinder Head Cover 100k002801t010 Inlet Manifold 100k002801t014 Camshaft 100k002801t015 Gear Case 100k002801t016 Water Pump 100k002801t017 Water Flange And Thermostat 100k002801t018 Fuel Camshaft 100k002801t019 Injection Pump 100k002801t020 Injection Pump [component Parts] 100k002801t021 Engine Stop Lever 100k002801t022 Speed Control Plate 100k002801t023 Governor 100k002801t01101 Air Cleaner 100k002801t01102 Double Air Cleaner [option] 100k002801t012 Pre-cleaner [option] 100k002801t01301 Exhaust Manifold And Muffler 100k002801t01302 Under Muffler [option] 100k002801t024 Stop Rod 100k002801t02501 Accelerator Lever 100k002801t02502 Accelerator Lever [hydrostatic Ps] 100k002801t026 Accelerator Linkage 100k0028fuel System 01t027 Fuel Tank 100k002801t028 Fuel Filter 100k002801t029 Fuel Filter [component Parts] 100k0028cooling Water System 01t03001 Fan [old Type] 100k002801t03002 Fan [new Type] 100k002801t031 Water Pipe 100k002801t032 Radiator 100k002801t033 Reserve Tank 100k002801t034 Shutter 100k0028electrical System 01t03501 Dynamo [a] 100k002801t03601 Dynamo [component Parts] [a] 100k002801t037 Starter 100k002801t03801 Starter [component Parts] 100k002801t03802 Starter [component Parts] 100k002801t039 Battery 100k002801t040 Switch 100k002801t041 Panel 100k002801t042 Light 100k002801t04301 Electrical Wiring [a] 100k0028clutch 01t04401 Clutch [dual Clutch] 100k002801t04501 Clutch Lever [with Dual Clutch] 100k002801t04601 Clutch Pedal [with Dual Clutch] 100k002801t04701 Clutch Housing [with Dual Clutch] 100k0028transmission 01t048 Transmission Case 100k002801t04901 Main Shaft [with Dual Clutch] 100k002801t05001 Countershaft 1 [constant Mesh] 100k002801t05002 Countershaft 1 [synchro Mesh] 100k002801t051 Countershaft 2 100k002801t052 Pto Countershaft 1 [with Dual Clutch] 100k002801t053 Pto Countershaft 2 [with Dual Clutch] 100k002801t05501 Pto Shaft [with I.mid Pto] [a] 100k0028​
