Item Part No. Description BookENGINE 01T001 CRANKCASE 100K002501T002 OIL PAN 100K002501T003 PISTON AND CRANKSHAFT 100K002501T004 MAIN BEARING CASE 100K002501T00501 FLYWHEEL [WITH DUAL CLUTCH] 100K002501T006 CYLINDER HEAD 100K002501T007 VALVE AND ROCKER ARM 100K002501T008 NOZZLE AND GLOW PLUG 100K002501T009 CYLINDER HEAD COVER 100K002501T010 INLET MANIFOLD 100K002501T014 CAMSHAFT 100K002501T015 GEAR CASE 100K002501T016 WATER PUMP 100K002501T017 WATER FLANGE AND THERMOSTAT 100K002501T018 FUEL CAMSHAFT 100K002501T019 INJECTION PUMP 100K002501T020 INJECTION PUMP [COMPONENT PARTS] 100K002501T021 ENGINE STOP LEVER 100K002501T022 SPEED CONTROL PLATE 100K002501T023 GOVERNOR 100K002501T01101 AIR CLEANER 100K002501T01102 DOUBLE AIR CLEANER [OPTION] 100K002501T012 PRE-CLEANER [OPTION] 100K002501T01301 EXHAUST MANIFOLD AND MUFFLER 100K002501T01302 UNDER MUFFLER [OPTION] 100K002501T024 STOP ROD 100K002501T02501 ACCELERATOR LEVER 100K002501T02502 ACCELERATOR LEVER [HYDROSTATIC PS] 100K002501T026 ACCELERATOR LINKAGE 100K0025FUEL SYSTEM 01T027 FUEL TANK 100K002501T028 FUEL FILTER 100K002501T029 FUEL FILTER [COMPONENT PARTS] 100K0025COOLING WATER SYSTEM 01T03001 FAN [OLD TYPE] 100K002501T03002 FAN [NEW TYPE] 100K002501T031 WATER PIPE 100K002501T032 RADIATOR 100K002501T033 RESERVE TANK 100K002501T034 SHUTTER 100K0025ELECTRICAL SYSTEM 01T03501 DYNAMO [A] 100K002501T03601 DYNAMO [COMPONENT PARTS] [A] 100K002501T037 STARTER 100K002501T03801 STARTER [COMPONENT PARTS] 100K002501T03802 STARTER [COMPONENT PARTS] 100K002501T039 BATTERY 100K002501T040 SWITCH 100K002501T041 PANEL 100K002501T042 LIGHT 100K002501T04301 ELECTRICAL WIRING [A] 100K0025CLUTCH 01T04401 CLUTCH [DUAL CLUTCH] 100K002501T04501 CLUTCH LEVER [WITH DUAL CLUTCH] 100K002501T04601 CLUTCH PEDAL [WITH DUAL CLUTCH] 100K002501T04701 CLUTCH HOUSING [WITH DUAL CLUTCH] 100K0025TRANSMISSION 01T048 TRANSMISSION CASE 100K002501T04901 MAIN SHAFT [WITH DUAL CLUTCH] 100K002501T05001 COUNTERSHAFT 1 [CONSTANT MESH] 100K002501T05002 COUNTERSHAFT 1 [SYNCHRO MESH] 100K002501T051 COUNTERSHAFT 2 100K002501T052 PTO COUNTERSHAFT 1 [WITH DUAL CLUTCH] 100K002501T053 PTO COUNTERSHAFT 2 [WITH DUAL CLUTCH] 100K002501T05501 PTO SHAFT [WITH I.MID PTO] [A] 100K0025
