Kubota L3650F Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k002301t002 Oil Pan 100k002301t003 Piston And Crankshaft 100k002301t004 Main Bearing Case 100k002301t00501 Flywheel [with Dual Clutch] 100k002301t006 Cylinder Head 100k002301t007 Valve And Rocker Arm 100k002301t008 Nozzle And Glow Plug 100k002301t009 Cylinder Head Cover 100k002301t010 Inlet Manifold 100k002301t01101 Air Cleaner 100k002301t01102 Double Air Cleaner [option] 100k002301t012 Pre-cleaner [option] 100k002301t01301 Exhaust Manifold And Muffler 100k002301t01302 Under Muffler [option] 100k002301t014 Camshaft 100k002301t015 Gear Case 100k002301t016 Water Pump 100k002301t017 Water Flange And Thermostat 100k002301t018 Fuel Camshaft 100k002301t019 Injection Pump 100k002301t020 Injection Pump [component Parts] 100k002301t021 Engine Stop Lever 100k002301t022 Speed Control Plate 100k002301t023 Governor 100k002301t024 Stop Rod 100k002301t02501 Accelerator Lever 100k002301t026 Accelerator Linkage 100k0023fuel System 01t027 Fuel Tank 100k002301t028 Fuel Filter 100k002301t029 Fuel Filter [component Parts] 100k0023cooling Water System 01t03002 Fan [new Type] 100k002301t031 Water Pipe 100k002301t032 Radiator 100k002301t033 Reserve Tank 100k002301t034 Shutter 100k0023electrical System 01t03501 Dynamo [a] 100k002301t03601 Dynamo [component Parts] [a] 100k002301t037 Starter 100k002301t038 Starter [component Parts] 100k002301t039 Battery 100k002301t040 Switch 100k002301t041 Panel 100k002301t042 Light 100k002301t04301 Electrical Wiring [a] 100k0023clutch 01t04401 Clutch [dual Clutch] 100k002301t04501 Clutch Lever [with Dual Clutch] 100k002301t04601 Clutch Pedal [with Dual Clutch] 100k002301t04701 Clutch Housing [with Dual Clutch] 100k0023transmission 01t048 Transmission Case 100k002301t04901 Main Shaft [with Dual Clutch] 100k002301t05002 Countershaft 1 [synchro Mesh] 100k002301t051 Countershaft 2 100k002301t052 Pto Countershaft 1 [with Dual Clutch] 100k002301t053 Pto Countershaft 2 [with Dual Clutch] 100k002301t05502 Pto Shaft [w/o I.mid Pto] 100k002301t057 Reverse Shaft 100k0023speed Change Lever 01t05801 Main And Shuttle Gear Shift Lever 100k002301t05901 Main Gear Shift Linkage System 100k0023​
