Item Part No. Description Book Engine 01t001 Crankcase 100k036301t002 Oil Pan 100k036301t003 Piston/crankshaft 100k036301t004 Main Bearing Case 100k036301t005 Flywheel 100k036301t006 Cylinder Head 100k036301t007 Valve And Rocker Arm 100k036301t008 Nozzle Holder/glow Plug 100k036301t009 Nozzle Holder [componentparts]100k036301t010 Cylinder Head Cover 100k036301t011 Inlet Manifold 100k036301t013 Exhaust Manifold 100k036301t015 Camshaft 100k036301t016 Gear Case 100k036301t017 Water Pump 100k036301t018 Water Flange And Thermostat 100k036301t019 Fuel Camshaft 100k036301t020 Injection Pump 100k036301t021 Injection Pump [componentparts]100k036301t022 Engine Stop Lever 100k036301t023 Speed Control Plate 100k036301t024 Governor 100k036301t025 Upper Gasket Kit 100k036301t026 Lower Gasket Kit 100k036302t012 Air Cleaner 100k036302t01401 Muffler 100k036302t01402 Under Muffler [option] 100k036302t027 Stop Rod 100k036302t028 Hand Accelerator Lever 100k0363fuel System 02t02902 Fuel Tank 100k036302t030 Fuel Filter/fuel Pipe 100k0363cooling Water System 02t031 Fan 100k036302t032 Water Pipe 100k036302t033 Radiator 100k036302t03401 Shutter [manual Strg.] 100k036302t03402 Shutter [power Strg.] 100k0363electrical System 02t035 Alternator 100k036302t036 Alternator [component Parts] 100k036302t037 Starter 100k036302t038 Starter [component Parts] 100k036302t039 Battery 100k036302t040 Switch 100k036302t041 Light 100k036302t042 Meter 100k036302t04302 Electrical Wiring 100k0363clutch 02t044 Clutch 100k036302t045 Clutch Lever 100k036302t046 Clutch Pedal 100k036302t047 Clutch Housing 100k0363transmission 02t048 Transmission Case 100k036302t049 Main Shaft 100k036302t050 Countershaft 100k036302t051 Pto Countershaft 100k036302t052 Reverse Shaft 100k0363
