Item Part No. Description Book Engine 010001 Crankcase 100k0654010002 Oil Pan 100k0654010003 Cylinder Head 100k0654010004 Gear Case 100k0654010005 Head Cover 100k0654010100 Main Bearing Case 100k0654010101 Camshaft And Idle Gear Shaft 100k0654010102 Piston And Crankshaft 100k065401010302 Flywheel [4wd] 100k0654010105 Fuel Camshaft 100k0654010200 Engine Stop Lever 100k0654010202 Injection Pump 100k0654010203 Injection Pump [componentparts]100k0654010204 Governor 100k0654010205 Speed Control Plate 100k0654010206 Nozzle Holder And Glow Plug 100k0654010207 Nozzle Holder [componentparts]100k0654010500 Water Flange And Thermostat 100k0654010501 Water Pump 100k0654010600 Valve And Rocker Arm 100k0654010601 Inlet Manifold 100k0654010901 Upper Gasket Kit 100k0654010902 Lower Gasket Kit 100k0654010603 Exhaust Manifold/muffler 100k0654010604 Air Cleaner 100k065401a003 Engine Stop Rod 100k065401a010 Accelerator Lever 100k065401a025 Accelerator Linkage 100k0654fuel System 01a101 Fuel Tank 100k065401a110 Fuel Pipe And Fuel Filter 100k065401a130 Fuel Filter [component Parts] 100k0654cooling Water System 01a401 Fan 100k065401a410 Water Pipe 100k065401a420 Radiator 100k065401a430 Reserve Tank 100k0654electrical System 01a515 Alternator 100k065401a520 Alternator [component Parts] 100k065401a525 Starter 100k065401a530 Starter [component Parts] 100k065401a535 Battery 100k065401b102 Switch 1 100k065401b103 Switch 2 100k065401b115 Panel Board 100k065401b120 Panel Board [component Parts] 100k065401b301 Light 100k065401b501 Electrical Wiring 100k0654transmission/clutch/rear Axle 01c101 Clutch 100k065401c201 Clutch Lever 100k065401c301 Clutch Pedal 100k065401c40102 Clutch Housing 100k065401c410 Mid Case 100k065401c42002 Transmission Case 100k065401d101 Main Shaft 100k065401d105 Countershaft 100k0654
