Item Part No. Description Book Engine 01t001 Crankcase 100k038201t002 Oil Pan 100k038201t003 Piston And Crankshaft 100k038201t004 Main Bearing Case 100k038201t005 Flywheel 100k038201t006 Cylinder Head 100k038201t007 Valve And Rocker Arm 100k038201t008 Nozzle Holder And Glow Plug 100k038201t009 Nozzle Holder [componentparets]100k038201t010 Cylinder Head Cover 100k038201t011 Inlet Manifold 100k038201t016 Camshaft 100k038201t017 Gear Case 100k038201t018 Water Pump 100k038201t019 Water Flange And Thermostat 100k038201t020 Injection Pump And Fuelcamshaft100k038201t021 Injection Pump [componentparts]100k038201t022 Speed Control Plate 100k038201t023 Governor 100k038201t024 Upper Gasket Kit 100k038201t025 Lower Gasket Kit 100k038202t012 Air Cleaner 100k038202t013 Air Cleaner [component Parts] 100k038202t014 Exhaust Manifold 100k038202t01501 Muffler 100k038202t01502 Under Muffler [old Type][option]100k038202t01503 Under Muffler [new Type][option]100k038202t026 Hand Accelerator Lever 100k0382fuel System 02t02701 Fuel Tank 100k038202t028 Fuel Filter And Fuel Pipe 100k0382cooling Water System 02t029 Water Pipe 100k038202t030 Radiator 100k038202t031 Shutter 100k0382electrical System 02t032 Dynamo And Fan 100k038202t033 Dynamo [component Parts] 100k038202t034 Starter 100k038202t035 Starter [component Parts] 100k038202t036 Battery 100k038202t037 Switch 100k038202t03801 Light [oil Type] 100k038202t03802 Light [new Type] 100k038202t03901 Regulator And Meter [oil Type] 100k038202t03902 Regulator And Meter 100k038202t04001 Electrical Wiring [old Type] 100k038202t04002 Electrical Wiring [new Type] 100k0382clutch 02t041 Clutch 100k038202t042 Clutch Lever 100k038202t043 Clutch Pedal 100k038202t044 Clutch Housing 100k0382transmission 02t045 Transmission Case 100k038202t046 Main Shaft 100k038202t047 Countershaft 100k038202t04801 Pto Countershaft 100k038202t049 Reverse Shaft 100k0382speed Change Lever 02t050 Main Gear Shift Lever 100k0382
