Kubota L2500F Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k036201t002 Oil Pan 100k036201t003 Piston/crankshaft 100k036201t004 Main Bearing Case 100k036201t005 Flywheel 100k036201t006 Cylinder Head 100k036201t007 Valve And Rocker Arm 100k036201t008 Nozzle Holder/glow Plug 100k036201t009 Nozzle Holder [component Parts] 100k036201t010 Cylinder Head Cover 100k036201t011 Inlet Manifold 100k036202t012 Air Cleaner 100k036201t013 Exhaust Manifold 100k036202t01401 Muffler 100k036202t01402 Under Muffler [option] 100k036201t015 Camshaft 100k036201t016 Gear Case 100k036201t017 Water Pump 100k036201t018 Water Flange And Thermostat 100k036201t019 Fuel Camshaft 100k036201t020 Injection Pump 100k036201t021 Injection Pump [component Parts] 100k036201t022 Engine Stop Lever 100k036201t023 Speed Control Plate 100k036201t024 Governor 100k036201t025 Upper Gasket Kit 100k036201t026 Lower Gasket Kit 100k036202t027 Stop Rod 100k036202t028 Hand Accelerator Lever 100k0362fuel System 02t02901 Fuel Tank 100k036202t030 Fuel Filter/fuel Pipe 100k0362cooling Water System 02t031 Fan 100k036202t032 Water Pipe 100k036202t033 Radiator 100k036202t03401 Shutter [manual Strg.] 100k0362electrical System 02t035 Alternator 100k036202t036 Alternator [component Parts] 100k036202t037 Starter 100k036202t038 Starter [component Parts] 100k036202t039 Battery 100k036202t040 Switch 100k036202t041 Light 100k036202t042 Meter 100k036202t04301 Electrical Wiring 100k0362clutch 02t044 Clutch 100k036202t045 Clutch Lever 100k036202t046 Clutch Pedal 100k036202t047 Clutch Housing 100k0362transmission 02t048 Transmission Case 100k036202t049 Main Shaft 100k036202t050 Countershaft 100k036202t051 Pto Countershaft 100k0362​
