Kubota L245DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01001 Crankcase 100k012901002 Cylinder Head 100k012901003 Gear Case 100k012901004 Bearing Case 100k012901005 Breather 100k012901006 Air Cleaner 100k01290100701 Muffler [l245dt] 100k01290100702 Muffler [l245] 100k012901008 Valve,rocker Arm 100k012901009 Head Cover 100k012901010 Camshaft 100k012901011 Piston Crankshaft 100k012901012 Flywheel 100k012901013 Nozzle Holder 100k012901014 Fuel Camshaft 100k012901015 Speed Control Plate 100k012901016 Governor 100k012901017 Dynamo 100k012901018 Radiator 100k012901019 Water Pump 100k012901020 Name Plate 100k012901063 Oil Filter 2 [section Parts] 100k012901064 Starter 100k012901065 Nozzle Holder 100k012901066 Injection Pump 100k012901067 Dynamo 100k0129electrical System 01024 Battery 100k0129clutch 01025 Clutch Housing 100k012901026 Clutch 100k012901027 Clutch Pedal 100k0129steering 01028 Steering 100k0129speed Change Lever 01029 Hand Accel 100k0129bonnet(Hood) And Chassis And Canopy 01030 Bonnet 100k0129electrical System 01031 Mirror Lamp 100k0129bonnet(Hood) And Chassis And Canopy 01032 Seat 100k0129transmission 01033 Transmission Case 100k012901034 Gear Drive System 1 100k012901035 Gear Drive System 2 100k012901036 Gear Drive System 3 100k0129speed Change Lever 01037 Speed Change System 1 100k012901038 Speed Change System 2 100k012901039 Change Laver 100k0129rear Axle And Rear Wheel 01040 Differential System 1 100k012901041 Differential System 2 100k012901042 Rear Axle 100k012901043 Axle Case 100k0129brake 01044 Brake 100k012901045 Brake Pedal 100k0129bonnet(Hood) And Chassis And Canopy 0104602 Fender [u.s.a] 100k0129electrical System 01047 Electical 1 100k012901048 Electical 2 100k012901049 Electical 3 100k0129fuel System 01050 Fuel Tank 100k012901051 Fuel Filter 100k0129hydraulic System 01052 Oil Pressure 1 100k012901053 Oil Pressure 2 100k012901054 O/p Cylinder 100k0129​
