Item Part No. Description Book Engine 021001 Crank Case 100a0166021002 Oil Pan 100a0166021003 Cylinder Head 100a0166021004 Gear Case 100a0166021005 Head Cover 100a0166021006 Oil Filter 100a0166021100 Main Bearing Case 100a0166021101 Camshaft And Idle Gear Shaft 100a0166021102 Piston And Crankshaft 100a0166021103 Flywheel 100a0166021105 Fuel Camshaft And Governor Shaft 100a0166021201 Stop Solenoid 100a0166021202 Injection Pump 100a0166021203 Injection Pump [component Parts] 100a016602120401 Governor 100a016602120402 Governor 100a0166021205 Speed Control Plate 100a0166021206 Nozzle Holder And Glow Plug 100a0166021207 Nozzle Holder [component Parts] 100a0166021500 Water Flange And Thermostat 100a0166021501 Water Pump 100a0166021600 Valve And Rocker Arm 100a0166021601 Inlet Manifold 100a0166021602 Exhaust Manifold 100a0166021700 Hydraulic Pump 100a0166021701 Hydraulic Pump [component Parts] 100a016602190001 Gasket Kit [upper] 100a016602190002 Gasket Kit [lower] 100a016603160301 Air Cleaner 100a016603160302 Air Cleaner 100a016603160303 Air Cleaner 100a0166031605 Muffler 100a0166fuel System 03a001 Accelerator Lever 100a016603a101 Fuel Tank 100a016603a120 Fuel Filter 100a0166cooling Water System 03a401 Fan 100a016603a42002 Radiator 100a016603a42502 Dustproof Plate 100a016603a501 Oil Switch And Thermo Sensor 100a0166electrical System 03a515 Alternator 100a016603a520 Alternator [component Parts] 100a016603a525 Starter 100a016603a530 Starter [component Parts] 100a016603a535 Battery 100a016603b101 Switch 100a016603b230 Electrical Wiring 100a016603b900 Tachometer Kit [option] 100a016603b910 Light Kit [option] 100a0166transmission 03c101 Clutch 100a016603c420 Transmission Case 100a016603c425 Differental Gear Case 100a016603d01501 Hst [component Parts] 100a016603d01502 Hst [component Parts] 100a016603d105 Universal Joint/fan 100a016603d120 Pto Shaft 100a0166front Axle 03d130 Front Differential 100a016603d140 Rear Wheel Propeller Shaft 100a0166
