Item Part No. Description Book Engine 010001 Crank Case 100a0163010002 Oil Pan 100a0163010003 Cylinder Head 100a0163010004 Gear Case 100a0163010005 Head Cover 100a0163010006 Oil Filter 100a0163010100 Main Bearing Case 100a0163010101 Camshaft And Idle Gear Shaft 100a0163010102 Piston And Crankshaft 100a0163010103 Flywheel 100a0163010105 Fuel Camshaft And Governor Shaft 100a0163010201 Stop Solenoid 100a0163010202 Injection Pump 100a0163010203 Injection Pump [component Parts] 100a016301020401 Governor 100a016301020402 Governor 100a0163010205 Speed Control Plate 100a0163010206 Nozzle Holder And Glow Plug 100a0163010207 Nozzle Holder [component Parts] 100a0163010500 Water Flange And Thermostat 100a0163010501 Water Pump 100a0163010600 Valve And Rocker Arm 100a0163010601 Inlet Manifold 100a0163010602 Exhaust Manifold 100a0163010700 Hydraulic Pump 100a0163010701 Hydraulic Pump [component Parts] 100a016301090001 Gasket Kit [upper] 100a016301090002 Gasket Kit [lower] 100a016303060301 Air Cleaner 100a016303060302 Air Cleaner 100a016303060303 Air Cleaner 100a0163030605 Muffler 100a0163fuel System 03a001 Accelerator Lever 100a016303a101 Fuel Tank 100a016303a120 Fuel Filter 100a0163cooling Water System 03a401 Fan 100a016303a42001 Radiator 100a016303a42501 Dustproof Plate 100a016303a501 Oil Switch And Thermo Sensor 100a0163electrical System 03a515 Alternator 100a016303a520 Alternator [component Parts] 100a016303a525 Starter 100a016303a530 Starter [component Parts] 100a016303a535 Battery 100a016303b101 Switch 100a016303b230 Electrical Wiring 100a016303b900 Tachometer Kit [option] 100a016303b910 Light Kit [option] 100a0163transmission 03c101 Clutch 100a016303c420 Transmission Case 100a016303c425 Differental Gear Case 100a016303d01501 Hst [component Parts] 100a016303d01502 Hst [component Parts] 100a016303d105 Universal Joint/fan 100a016303d120 Pto Shaft 100a0163front Axle 03d130 Front Differential 100a016303d140 Rear Wheel Propeller Shaft 100a016303d145 One-way Clutch [component Parts] 100a016303d300 Front Axle Case 100a0163
