Kubota F2400 Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01g001 Crankcase 100k051601g002 Oil Pan 100k051601g003 Piston/crankshaft 100k051601g004 Main Bearing Case 100k051601g005 Flywheel 100k051601g006 Cylinder Head 100k051601g007 Valve/rocker Arm 100k051601g008 Nozzle Holder 100k051601g00901 Nozzle Holder [component Parts] 100k051601g00902 Nozzle Holder [component Parts] 100k051601g010 Head Cover 100k051601g011 Inlet Manifold 100k051601g014 Camshaft 100k051601g015 Gear Case 100k051601g016 Water Pump 100k051601g017 Water Flange 100k051601g018 Fuel Camshaft 100k051601g019 Injection Pump 100k051601g02001 Injection Pump [component Parts] 100k051601g02002 Injection Pump [component Parts] 100k051601g021 Engine Stop Lever 100k051601g02201 Speed Control Plate 100k051601g02202 Speed Control Plate 100k051601g023 Governor 100k051601g024 Upper Gasket Kit 100k051601g025 Lower Gasket Kit 100k0516cooling Water System 01g05601 Fan 100k0516electrical System 01g05901 Alternator 100k051601g06001 Alternator [component Parts] 100k0516clutch 01g06601 Clutch 100k0516hydraulic System 01g10501 Hydraulic Pump 100k051601g10601 Hydraulic Pump [component Parts] 100k0516engine 02g012 Air Cleaner [f2400] 100k051602g013 Muffler [f2400] 100k051602g052 Accelerator Lever 100k0516fuel System 02g053 Fuel Tank 100k051602g05401 Fuel Pipe [f2400] 100k051602g05501 Fuel Filter [f2400] [component Parts] 100k0516cooling Water System 02g05701 Radiator [f2400] 100k051602g05801 Dustproof Plate [f2400] 100k0516electrical System 02g06101 Starter [f2400] 100k051602g06201 Starter [f2400] [component Parts] 100k051602g063 Electrical System 1 100k051602g064 Electrical System 2 100k051602g065 Light Kit [option] 100k0516clutch 02g067 Propeller Shaft 100k051602g068 Diff.lock/clutch Rod 100k051602g069 Clutch Rod 100k051602g070 Clutch Housing Frame 100k0516transmission 02g071 Transmission Case 100k051602g072 Transmission Case Cover 100k051602g07301 Hst [f2400] 100k051602g074 Hst [component Parts] 100k051602g075 Second Shaft 100k051602g076 Third/fifth Shaft 100k051602g077 Fourth Shaft 100k0516speed Change Lever 02g078 Speed Change Fork And Pto Lever 100k0516​
