Item Part No. Description Book Engine 01t001 Crankcase 100k031501t002 Oil Pan 100k031501t003 Piston/crankshaft 100k031501t004 Main Bearing Case 100k031501t005 Flywheel 100k031501t006 Cylinder Head 100k031501t007 Valve/rocker Arm 100k031501t008 Nozzle Holder [a] [ca] [fr] [au] 100k031501t010 Nozzle Holder (Component Parts) 100k031501t011 Cylinder Head Cover 100k031501t012 Inlet Manifold 100k031501t014 Exhaust Manifold 100k031501t016 Camshaft 100k031501t017 Gear Case 100k031501t018 Hydraulic Gear Pump 100k031501t019 Hydraulic Gear Pump (Component Parts) 100k031501t020 Fuel Pump 100k031501t021 Injection Pump 100k031501t022 Injection Pump (Component Parts) 100k031501t023 Speed Control Plate 100k031501t024 Governor 100k0315electrical System 01t029 Dynamo/fan [a] [ca] [fr] [au] [wg] 100k031501t030 Dynamo (Component Parts) [a] [ca] [fr] [au] [wg] 100k0315clutch 01t048 Clutch 100k0315labels 01t096 Label 100k0315engine 01t013 Air Cleaner 100k031501t015 Muffler 100k031501t025 Accelerator 100k0315fuel System 01t026 Fuel Tank 100k031501t027 Fuel Filter 100k0315cooling Water System 01t028 Radiator 100k0315electrical System 01t035 Starter 100k031501t036 Starter (Component Parts) 100k031501t037 Battery 100k031501t038 Panel Wiring [a] [ca] 100k031501t041 Light/horn [a] [ca] 100k031501t047 Switch 100k0315clutch 01t049 Clutch Pedal/propeller Shaft 100k031501t050 Clutch Housing 100k0315transmission 01t051 Transmission Case 100k031501t052 Case Cover 100k031501t053 1st Shaft 4th Shaft 100k031501t054 2nd Shaft Reverse Shaft 100k031501t055 3rd Shaft 5th Shaft Pto Shaft [a] [ca] 100k031501t057 Mid P.t.o. 100k0315speed Change Lever 01t058 Main Gear Shift Lever 100k031501t059 Hi-lo Gear Shift Lever 100k0315rear Axle/rear Wheel 01t060 Differential Rear 100k031501t061 Axle Case 100k031501t062 Rear Wheel (7-16) 100k031501t063 Rear Wheel (212/80d-15) [a] [ca] 100k0315brake 01t065 Brake 100k031501t066 Brake Pedal [a] [ca] [fr] [au] 100k0315front Axle/front Wheel 01t069 Drive Shaft 100k031501t070 Front Axle Case 100k031501t071 Front Wheel Gear Case 100k031501t072 Differential Front 100k031501t073 Front Axle Joint 100k031501t074 Front Wheel Drive Lever 100k031501t075 Front Wheel (4.50-10) 100k0315
