Kubota M4050 Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01001 Crankcase 100k040101002 Cylinder 100k040101003 Gear Case 100k040101004 Bearing Case 100k040101005 Breather 100k04010100601 Air Cleaner [a][ca] 100k040101007 Muffler 100k040101008 Valve 100k040101009 Head Cover 100k040101010 Camshaft 100k040101011 Crankshaft 100k040101012 Flywheel 100k040101013 Nozzle Holder 100k040101014 Speed Control 100k040101015 Governor 100k040101016 Dynamo 100k040101017 Radiator 100k040101018 Name Plate 100k040101019 Injection Pump 100k040101020 Water Pump 100k040101103 Oil Filter 2 [section Parts] 100k040101104 Starter [section Parts] 100k040101105 Nozzle Holder 2 [section Parts] 100k040101106 Dynamo [section Parts] 100k040101107 Injection Pump [section Parts] 100k0401fuel System 01021 Fuel Tank 1 100k040101022 Fuel Tank 2 100k040101023 Accel Rod 100k040101024 Hand Accel 100k0401cooling Water System 01025 Radiator Support 100k0401clutch 01026 Clutch Housing 100k040101027 Change Cover 100k0401transmission 0102801 Transmission [a][ca] 100k0401front Axle And Front Wheel 0102901 Front Axle [a][ca] 100k0401clutch 01030 Clutch 100k040101031 Clutch Pedal 100k0401speed Change Lever 01032 Lever 100k0401transmission 01033 Mission Gear 1 100k04010103401 Mission Gear 2 [a][ca] 100k040101035 Mission Gear 3 100k0401speed Change Lever 0103601 1,2 Shift Lever [a][ca] 100k040101037 Main Change Lever 100k0401transmission 01038 Bearing Support Change Lever 100k040101039 Diff Support 100k0401speed Change Lever 01040 Diff Lock 100k040101041 Bevel Pinion 100k0401rear Axle And Rear Wheel 01042 Axle Case 100k040101043 Rear Axle 100k04010104401 Front Wheel Hub [a] 100k04010104501 Rear Wheel [a] 100k040101046 Front Axle 100k040101047 Knuckle Shaft 100k0401steering 01048 Steering 100k040101049 Steering Lever 100k0401hydraulic System 01050 Power Steering 1 100k040101051 Power Steering 2 100k040101052 Booster 100k0401brake 01053 Brake 100k040101054 Brake Pedal 100k0401​
