Kubota L2050DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k032201t002 Oil Pan 100k032201t003 Piston And Crankshaft 100k032201t004 Main Bearing Case 100k032201t005 Flywheel 100k032201t006 Cylinder Head 100k032201t007 Valve And Rocker Arm 100k032201t008 Nozzle Holder And Glow Plug 100k032201t009 Nozzle Holder [component Parts] 100k032201t010 Cylinder Head Cover 100k032201t011 Inlet Manifold 100k032201t015 Camshaft 100k032201t016 Gear Case 100k032201t017 Water Pump 100k032201t018 Water Flange 100k032201t019 Injection Pump And Fuel Camshaft 100k032201t020 Injection Pump [component Parts] 100k032201t021 Speed Control Plate 100k032201t022 Governor 100k0322rear Axle And Rear Wheel 01t060 Differential (Rear) 100k0322engine 01t012 Air Cleaner 100k032201t013 Exhaust Manifold 100k032201t014 Muffler 100k032201t023 Hand Accelerator 100k0322fuel System 01t025 Fuel Tank 100k032201t026 Fuel Filter 100k0322cooling Water System 01t027 Water Pipe 100k032201t028 Radiator 100k032201t029 Shutter 100k0322electrical System 01t030 Dynamo 100k032201t031 Dynamo [component Parts] 100k032201t032 Starter 100k032201t033 Starter [component Parts] 100k032201t034 Battery 100k032201t035 Switch And Horn 100k032201t036 Light 100k032201t038 Regulator And Meter 100k032201t040 Electrical Wiring 100k0322clutch 01t041 Clutch 100k032201t042 Clutch Lever 100k032201t043 Clutch Pedal 100k032201t044 Clutch Housing 100k0322transmission 01t045 Transmission Case 100k032201t046 Main Shaft 100k032201t047 Counter Shaft 100k032201t049 Pto Counter Shaft [a] 100k032201t051 Reverse Shaft 100k0322speed Change Lever 01t052 Main Gear Shift Lever [a] 100k032201t053 Pto Gear Shift Lever [a] 100k032201t055 Main Shift Fork 100k032201t056 Pto Shift Fork [a] 100k032201t058 Hi-lo Gear Shift Fork And Lever 100k0322rear Axle And Rear Wheel 01t059 Spiral Bevel Gear 100k032201t061 Diff. Lock Pedal 100k032201t062 Rear Axle 100k032201t064 Rear Wheel (9.5-24f) 100k032201t065 Rear Wheel (11.2-24f) 100k032201t066 Rear Wheel (13.6-16t) 100k0322brake 01t069 Brake 100k032201t070 Brake Pedal 100k0322​
