Item Part No. Description Book Engine 010001 Crankcase 100k0617010002 Oil Pan 100k0617010003 Cylinder Head 100k0617010004 Gear Case 100k0617010005 Head Cover 100k0617010100 Main Bearing Case 100k0617010101 Camshaft And Idle Gear Shaft 100k0617010102 Piston And Crank Shaft 100k0617010103 Flywheel 100k0617010105 Fuel Camshaft And Governor Shaft 100k0617010201 Stop Solenoid 100k0617010202 Injection Pump 100k0617010204 Governor 100k0617010205 Speed Control Plate 100k0617010206 Nozzle Holder And Glow Plug 100k0617010207 Nozzle Holder [component Parts] 100k0617010500 Water Flange And Thermostat 100k0617010501 Water Pump 100k0617010600 Valve And Rocker Arm 100k0617010601 Inlet Manifold 100k0617010602 Exhaust Manifold 100k061701090001 Upper Gasket Kit 100k061701090002 Lower Gasket Kit 100k061701090003 Lower Gasket Kit 100k0617electrical System 01a521 Dynamo 100k061701a523 Dynamo [component Parts] 100k0617clutch 01c101 Clutch 100k0617hydraulic System 01j120 Hydraulic Pump 100k061701j125 Hydraulic Pump [component Parts] 100k0617engine 02060301 Air Cleaner 100k061702060302 Air Cleaner 100k061702060303 Air Cleaner (Double) [option] 100k0617020605 Muffler 100k0617fuel System 02a001 Accelerator Lever 100k061702a101 Fuel Tank 100k061702a110 Fuel Pipe 100k061702a11001 Fuel Pipe 100k061702a130 Fuel Filter [component Parts] 100k0617cooling Water System 02a401 Fan 100k061702a410 Water Pipe 100k061702a420 Radiator 100k0617electrical System 02a525 Starter 100k061702a530 Starter [component Parts] 100k061702a535 Battery 100k061702b115 Panel Board 100k061702b120 Panel Board [component Parts] 100k061702b301 Head Light 100k061702b302 Tail Light/hazard Light/working Light 100k061702b50101 Electrical Wiring 100k0617clutch 02c110 Clutch Rod 100k061702c301 Clutch Pedal 100k061702c401 Clutch Housing 100k0617frame 02c415 Frame 100k0617transmission 02c420 Transmission Case 100k061702c425 Differential Gear Case 100k061702c427 Rear Axle Case 100k061702d001 Clutch Shaft/propeller Shaft 100k061702d105 2nd Shaft/3rd Shaft/4th Shaft 100k061702d135 5th Shaft/pto Shaft 100k0617
