Item Part No. Description Book Engine 010001 Crankcase 100k0614010002 Oil Pan 100k0614010003 Cylinder Head 100k0614010004 Gear Case 100k0614010005 Head Cover 100k0614010100 Main Bearing Case 100k0614010101 Camshaft And Idle Gear Shaft 100k0614010102 Piston And Crank Shaft 100k0614010103 Flywheel 100k0614010105 Fuel Camshaft And Governor Shaft 100k0614010201 Stop Solenoid 100k0614010202 Injection Pump 100k0614010203 Injection Pump [component Parts] 100k0614010204 Governor 100k0614010205 Speed Control Plate 100k0614010206 Nozzle Holder And Glow Plug 100k0614010207 Nozzle Holder [component Parts] 100k0614010500 Water Flange And Thermostat 100k0614010501 Water Pump 100k0614010600 Valve And Rocker Arm 100k0614010601 Inlet Manifold 100k0614010602 Exhaust Manifold 100k061401090001 Upper Gasket Kit 100k061401090002 Lower Gasket Kit 100k0614electrical System 01a521 Dynamo 100k061401a523 Dynamo [component Parts] 100k0614clutch 01c101 Clutch 100k0614hydraulic System 01j120 Hydraulic Pump 100k061401j125 Hydraulic Pump [component Parts] 100k0614engine 02060301 Air Cleaner 100k061402060302 Air Cleaner 100k061402060303 Air Cleaner(Double) [option] 100k0614020605 Muffler 100k0614fuel System 02a001 Accelerator Lever 100k061402a101 Fuel Tank 100k061402a110 Fuel Pipe 100k061402a11001 Fuel Pipe 100k061402a130 Fuel Filter [component Parts] 100k0614cooling Water System 02a401 Fan 100k061402a410 Water Pipe 100k061402a420 Radiator 100k0614electrical System 02a525 Starter 100k061402a530 Starter [component Parts] 100k061402a535 Battery 100k061402b115 Panel Board 100k061402b120 Panel Board [component Parts] 100k061402b301 Head Light 100k061402b302 Tail Light/hazard Light/working Light 100k061402b50101 Electrical Wiring 100k0614clutch 02c110 Clutch Rod 100k061402c301 Clutch Pedal 100k061402c401 Clutch Housing 100k0614frame 02c415 Frame 100k0614transmission 02c420 Transmission Case 100k061402c425 Differential Gear Case 100k061402c427 Rear Axle Case 100k061402d001 Clutch Shaft/propeller Shaft 100k061402d105 2nd Shaft/3rd Shaft/4th Shaft 100k061402d135 5ht Shaft/pto Shaft 100k061402d137 Mid Pto 100k0614
