Kubota B1550DB1550D Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k019301t002 Oil Pan 100k019301t003 Piston/crankshaft 100k019301t004 Main Bearing Case 100k019301t005 Flywheel 100k019301t006 Cylinder Head 100k019301t007 Valve/rocker Arm 100k019301t008 Nozzle Holder 100k019301t009 Nozzle Holder [component Parts] 100k019301t010 Cylinder Head Cover 100k019301t011 Inlet Manifold 100k019301t013 Exhaust Manifold 100k019301t015 Camshaft 100k019301t016 Gear Case 100k019301t017 Water Pump 100k019301t018 Tension Pulley [ca] 100k019301t019 Water Flange 100k019301t020 Fuel Pump 100k019301t021 Injection Pump 100k019301t022 Injection Pump [component Parts] 100k019301t023 Engine Stop Lever 100k019301t024 Speed Control Plate 100k019301t025 Governor 100k019301t026 Upper Gasket Kit 100k019301t027 Lower Gasket Kit 100k0193electrical System 01t03501 Dynamo [a Au] 100k019301t03502 Alternator [ca] 100k019301t03601 Dynamo [a Au] [component Parts] 100k019301t03602 Alternator [ca] [component Parts] 100k0193clutch 01t045 Clutch 100k0193hydraulic System 01t094 Hydraulic Gear Pump 100k019301t095 Hydraulic Gear Pump [component Parts]100k0193engine 02t012 Air Cleaner 100k019302t01401 Muffler 100k019302t01402 Horizontal Muffler [option] 100k019302t028 Engine Stop Rod 100k019302t029 Accelerator Lever 100k0193fuel System 02t030 Fuel Tank 100k019302t031 Fuel Pipe 100k019302t032 Fuel Filter [component Parts] 100k0193cooling Water System 02t03301 Water Pipe 100k019302t03401 Radiator 100k0193electrical System 02t037 Starter 100k019302t038 Starter [component Parts] 100k019302t039 Battery 100k019302t040 Light 100k019302t041 Working Light [option] 100k019302t04201 Panel / Switch [a Au] 100k019302t04202 Panel / Switch [ca] 100k019302t043 Panel Board [component Parts] 100k019302t04401 Wire Harness [a Au] 100k019302t04402 Wire Harness [ca] 100k0193clutch 02t046 Clutch Rod 100k019302t047 Clutch Pedal 100k019302t048 Clutch Housing 100k0193​
