CRANKCASE GROUP, CARTER MOTEUR33-474518 122 16 13 610 15-12.19 30(Z500-1 AO20-1132-2926 -7823 -2739 37 38 36 35 303421-15-B-226-21Code M Quantity Ref. Part Name Description Description Na Code No Unit Remarks15261-0101-3 Crankcase Comp ASSY, crankcase 2Carter complete 1 -Crankcase CRANKCASE Complete 3 06311-75015 Beltplug PLUG, expansion bouchon expansible 34 06311-75040 Beltplug PLUG, expansion bouchon expansible 15 15321-9626-3 15221-0349-3 15221-9601-2 15261-9601-2 15521-0602-2 15521-9603-2 15521-9604-2 15521-9605-2 15521-9606-2 15521-9607-2 15521-9608-2 15521-9609-2 15012-00609 15012-00814 15012-00814 15012-00814 15221-3365-2 15221-3365-3 15221-3365-4 15221-3365-5 15221-3365-6 15221-3365-7 15221-3365-8 15221-3365-9 15221-3365-10 15221-3365-11 15221-3365-12 15221-3365-13 15221-3365-14 15221-3365-15 15221-3365-16 15221-3365-17 15221-3365-18 15221-3365-19 15221-3365-20 15221-3365-21 15221-3365-22 15221-3365-23 15221-3365-24 15221 15231-3396-1 PIN, pipe 14 Centrifugal separator 215261-7288-1 Water pipe 2 PIPE, water pipe 115 15261-0231-1 LINER, cylinder liner 216 15221-3370-1 O-RING, torique joint 117 15261-7391-3 COVER, water cover 118 15261-7392-1 GASKET, water cover joint 19 101023-50620 BOLT 22021 15262-0161-3 Oil inlet 22 15261-0162-2 Oil pan Gasket 23 15381-9109-1 Porto OIL, pan GASKET, oil pan BOLT Carter d'huile 1 Joint de carter d'huille 1 Boulon 24 14
