lug,expansion 1 0.055060 15221-03380 Cap,sealing 6 0.037070 15221-03390 Cap,sealing 2 0.066page 3ref Part Number Part Name Qty Ic S/n Lbs Remarkscrank Case080 15261-03370 Cap,sealing 1 0.011090 1a091-03380 Plug,weight Shaft 2 0.011100 05012-00408 Pin,straight 2 0.002110 05012-00609 Pin,straight 3 0.006120 05012-00612 Pin,straight 2 0.006130 05012-01018 Pin,straight 1 0.026140 15221-33650 Pin,pipe 1 0.008150 15321-73340 Pipe,water Return 1 0.035155 1a091-26990 Metal,weight Shaft 2 0.057160 1a091-26980 Metal,weight Shaft 2 0.048170 1a091-26970 Metal,weight Shaft 2 0.026180 1j860-33140 Plug,oil Filler 1 0.066190 1a021-33110 Flange,oil Filler 1 0.154200 1a021-51660 Gasket,pump Cover 1 0.006210 01023-50618 Bolt 2 0.013220 15471-35013 Assy Pump,oil 1 1.21230 1a021-35150 Gasket,oil Pump 1 0.002240 01023-60650 Bolt 4 0.033250 17301-35663 Gear,oil Pump Drive 1 0.473260 05712-00410 Key,feather 1 0.002270 15221-35682 Nut,flange 1 0.030280 1a053-57482 Bracket,accel.cable 1 0.169290 01023-50622 Bolt 2 0.011
