Kubota RCK54TG Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Mower 05j015 Center Pulley 100a017105j050 Blade/cover 100a017105j100 Tension Arm 100a017105j20001 Mower Deck And Cover 100a017105j300 Gauge Wheel 100a017105j500 Front Link Lever 100a017105j800 Mower Label 100a0171 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)010 K5221-71160 Assy Holder Pulley 1 <=24206 2.23 4.906010 K5221-71460 Assy Holder Pulley 1 >=24207 ¬ 0 0020 K5221-71210 Holder Pulley 1 0 0030 08101-06205 Bearing Ball 2 0.14 0.308040 K5221-71130 Collar 1 0 0050 K5221-71270 Shaft Blade 1 <=24206 0 0050 K5221-71290 Shaft Blade 1 >=24207 ¹ 0 0060 K5221-71230 Cover Dust 1 0.112 0.2464070 K5221-71920 Blade 1 <=24206 0 0070 K5351-34330 Blade 1 >=24207 ¹ 0 0080 K5112-71330 Spring Plate 1 <=24206 0.04 0.088080 K5371-34350 Spring Corn 2 >=24207 ¹ 0 0085 K5371-34390 Washer Lock 1 >=24207 0 0090 01176-51230 Bolt 1 <=24206 0.03 0.066090 K5371-34370 Bolt Blade 1 >=24207 ¹ 0 0100 70722-34120 Oil Seal Upper 1 0.025 0.055110 70725-34162 Oil Seal Lower 1 0.024 0.0528120 05712-00760 Key Feather 1 0.022 0.0484130 01073-51230 Bolt 4 0.041 0.0902140 02074-50120 Nut 4 0.015 0.033150 04512-60120 Washer Spring 4 0.005 0.011160 K5221-71260 Pulley Blade Center 1 0 0170 02074-50160 Nut 1 0.029 0.0638180 75599-33017 Washer Spring 1 <=16695 0 0180 04512-60160 Washer Spring 1 >=16696 ¬ 0.01 0.022190 K5651-34560 Washer Plain 1 0.024 0.0528200 K5221-72820 Plate Center Pulley 1 0 0210 K5221-51310 V-belt 1 <=16695 0 0210 K5221-51350 Belt 1 >=16696 ¬ 0 0220 K1122-15150 Nipple Grease 1 <=16695 0.002 0.0044220 K5221-71280 Fitting Grease 1 >=16696 ¬ 0 0​
