Kubota RCK48LTB Instructions for Parts Books - Instruction Manual
Item Part No. Description Bookmower 05j100 Tension Pulley/mower Belt 100a019405j20001 Mower Deck And Cover 100a019405j300 Gauge Wheel 100a019405j800 Mower Label 100a0194 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)020 K5112-71210 Holder Pulley 3 0.55 1.21030 08141-06205 Bearing Ball 6 0.118 0.2596040 K5112-71130 Collar 3 0.04 0.088050 K5112-71220 Shaft Blade 3 0.56 1.232060 76516-61563 Cover Lower 3 0.02 0.044070 K5181-71920 Blade 3 0 0080 K5112-71330 Spring Plate 3 0.04 0.088090 01176-51230 Bolt Blade 3 0.03 0.066100 76516-61563 Cover Lower 3 0.02 0.044110 75599-04320 Hex.bolt 12 0.02 0.044120 75599-31023 Nut 12 0.006 0.0132130 75599-33013 Washer Spring 12 0.01 0.022140 05712-00720 Key Feather 3 0.008 0.0176150 K5112-71140 Pulley Blade 2 0.73 1.606155 K5142-71140 Pulley Blade Rh 1 0 0160 02074-50160 Nut 3 0.029 0.0638170 04512-60160 Washer Spring 3 0.01 0.022180 75599-32017 Washer Plain 3 0 0190 K5112-72810 Plate Holder Pulley 2 0.17 0.374200 K5182-71410 Belt Mower 1 0.5 1.1210 K5142-72810 Plate Holder Pulley 1 0 0220 04015-50100 Washer Plain 1 0.016 0.0352230 04512-60100 Washer Spring 1 0.002 0.0044240 01053-51020 Bolt 1 0.02 0.044250 K5142-72620 Cover Belt Lh 1 0 0260 K5142-72630 Cover Belt Rh 1 0 0270 01754-50816 Bolt Flange 6 0.011 0.0242280 K5181-97520 Kit Blade 1 Std 0 0280 K5182-97520 Kit Blade 1 Low Suction 0 0290 K5181-71920 Blade 3 Std 0 0290 K5182-71820 Blade 48l(Low Lift) 3 Low Suction 0 0​
