Item Part No. Description Book Mower 04h100 Tension Pulley/mower Belt 100a019004h20001 Mower Deck And Cover 100a019004h300 Gauge Wheel 100a019004h800 Mower Label 100a0190 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)010 K5112-97560 Kit Holder Pulley 1 1.85 4.07020 K5112-71210 Holder Pulley 2 0.55 1.21030 08141-06205 Bearing Ball 4 0.118 0.2596040 K5112-71130 Collar 2 0.04 0.088050 K5112-71220 Shaft Blade 2 0.56 1.232060 76516-61563 Cover Bearing 2 <=11204 0.008 0.0176060 76516-61563 Cover Lower 2 >=11205 « 0.008 0.0176070 K5111-71920 Blade 2 1.07 2.354080 K5112-71330 Spring Plate 2 0.04 0.088090 01176-51230 Bolt Blade 2 0.003 0.0066100 K5112-71280 Cover Bearing 2 <=11204 0 0100 76516-61563 Cover Lower 2 >=11205 « 0.008 0.0176110 75599-04320 Hex.bolt 8 0.02 0.044120 75599-31023 Nut 8 0.006 0.0132130 75599-33013 Washer Spring 8 0.006 0.0132140 05712-00720 Key Feather 2 0.008 0.0176150 K5112-71140 Pulley Blade 2 0.73 1.606160 02074-50160 Nut 2 0.029 0.0638170 04512-60160 Washer Spring 2 0.01 0.022180 75599-32017 Washer Plain 2 0.014 0.0308190 K5112-72810 Plate Holder Pulley 2 0.17 0.374200 K5112-71410 Belt Mower 1 0.32 0.704210 K5112-72620 Cover Belt Lh 1 0.57 1.254220 K5112-72630 Cover Belt Rh 1 0.46 1.012230 01754-50816 Bolt Flange 6 0.011 0.0242240 K5111-97520 Kit Blade 1 Std 3 6.6240 K5112-97520 Kit Blade Lowsuction 1 Low Suction 3.11 6.842250 K5111-71920 Blade 2 Std 1.07 2.354250 K5112-71920 Blade Low Suction 2 Low Section 1.52 3.344
