Kubota R520S Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01000102 Crank Case 100a023101000202 Oil Pan 100a023101000302 Cylinder Head 100a0231010004 Gear Case 100a023101000502 Head Cover 100a023101010002 Main Bearing Case 100a023101010102 Camshaft And Idle Gear Shaft 100a023101010202 Piston And Crankshaft 100a023101010302 Flywheel 100a023101010502 Fuel Camshaft And Governor Shaft 100a0231010200 Engine Stop Lever 100a023101020202 Injection Pump 100a023101020402 Governor 100a0231010205 Speed Control Plate 100a023101020602 Nozzle Holder And Glow Plug 100a0231010413 Alternator 100a0231010414 Alternator (Component Parts) 100a023101041602 Starter 100a023101041702 Starter (Component Parts) 100a023101050002 Water Flange And Thermostat 100a023101050102 Water Pump 100a023101060002 Valve And Rocker Arm 100a023101061002 Inlet Manifold 100a023101061202 Exhaust Manifold 100a023101090002 Gasket Kit 100a023101090004 Gasket Kit 100a0231020030 Engine Bracket 100a0231020503 Water Pipe 100a0231020511 Radiator 100a023102061402 Air Cleaner 100a023102061602 Muffler 100a023102a00102 Drain Piping 100a0231fuel System 02a300 Fuel Piping 100a023102a301 Fuel Filter (Component Parts) 100a023102a303 Fuel Tank 100a0231electrical System 02b400 Battery 100a023102b402 Relay 100a023102b404 Switch And Meter 100a023102b406 Lamp 100a023102b407 Lamp [rops] 100a023102b408 Electrical Wiring 100a0231transmission 02c000 Mission Case 100a023102c100 Front Axle Case 100a023102c102 Front Axle 100a023102c200 Front Differential Case 100a023102c202 Planetary Gear (Front) 100a023102c204 Front Differential 100a023102c300 Rear Axle Case 100a023102c302 Rear Axle 100a023102c400 Rear Differential Case 100a023102c402 Planetary Gear (Rear) 100a023102c404 Rear Differential 100a023102c500 Propeller Shaft 100a0231tire 02d00002 Wheel/tire 100a0231steering 02e000 Steering Handle 100a023102e002 Hydraulic Oil Line (Steering) 100a023102e004 Streering Controller 100a0231speed Change 02e200 Accelerator Pedal 100a0231brake 02f000 Brake Pedal 100a0231​
