Item Part No. Description Book Engine 01000101 Crank Case 100a024001000201 Oil Pan 100a024001000301 Cylinder Head 100a0240010004 Gear Case 100a024001000501 Head Cover 100a024001010001 Main Bearing Case 100a024001010002 Main Bearing Case 100a024001010101 Camshaft And Idle Gear Shaft 100a024001010201 Piston And Crankshaft 100a024001010202 Piston And Crankshaft 100a024001010301 Flywheel 100a024001010501 Fuel Camshaft And Governor Shaft 100a0240010201 Stop Solenoid 100a024001020201 Injection Pump 100a024001020401 Governor 100a024001020501 Speed Control Plate 100a024001020601 Nozzle Holder And Glow Plug 100a0240010214 Boost Compensator 100a024001041301 Alternator 100a0240010414 Alternator (Component Parts) 100a024001041601 Starter 100a024001041701 Starter (Component Parts) 100a024001050001 Water Flange And Thermostat 100a024001050101 Water Pump 100a024001060001 Valve And Rocker Arm 100a0240010606 Turbo Charger 100a0240010608 Oil Pipe (Turbo Charger) 100a024001061001 Inlet Manifold 100a024001061201 Exhaust Manifold 100a0240010702 Oil Cooler 100a024001090001 Gasket Kit 100a024001090003 Gasket Kit 100a0240back Hoe 02s210 Outligger Control Lever / Slide Lock 100a024002s220 Operating Control Lever 100a024002s230 Control Arm 100a024002s240 Lock Rod 100a024002s25001 Control Cable 100a024002s25002 Control Cable 100a024002s260 Stand 100a024002s270 Cover 100a024002s300 Slide Frame 100a024002s310 Swing Bracket 100a024002s400 Boom 100a024002s420 Arm 100a024002s440 Bucket Link 100a024002s46001 Bucket 100a024002s46002 Bucket 100a024002s500 Out Ligger Cylinder 100a024002s510 Swing Cylinder 100a024002s530 Boom Cylinder 100a024002s540 Arm Cylinder 100a024002s550 Bucket Cylinder 100a024002s560 Slide Lock Cylinder 100a024002s600 Oil Piping Quick Coupler 100a024002s610 Oil Piping Out Ligger 100a024002s620 Oil Piping Slide Lock 1 100a024002s621 Oil Piping Slide Lock 2 100a024002s630 Oil Piping Boom 100a024002s640 Oil Piping Arm 100a0240
