Item Part No. Description Book Engine 010001 Crankcase 100k0546010002 Oil Pan 100k0546010003 Cylinder Head 100k0546010004 Gear Case 100k0546010005 Head Cover 100k0546010101 Camshaft And Idle Gear Shaft 100k0546010102 Piston And Crankshaft 100k0546010103 Flywheel 100k0546010106 Balancer 100k0546010202 Injection Pump 100k0546010203 Injection Pump [componentparts]100k0546010204 Governor 100k0546010206 Nozzle Holder And Glow Plug 100k0546010207 Nozzle Holder [componentparts]100k0546010209 Pump Housing 100k0546010212 Fork Lever (Governor) 100k0546010300 Fuel Filter 100k0546010500 Water Flange And Thermostat 100k0546010501 Water Pump 100k0546010600 Valve And Rocker Arm 100k0546010601 Inlet Manifold 100k0546010602 Exhaust Manifold 100k054601060802 Turbo Charger 100k0546010610 Actuator 100k0546010611 Oil Pipe(Turbo Charger) 100k054601070202 Hydraulic Pump Base [a] 100k054601070203 Hydraulic Pump Base [ca] 100k0546010705 Oil Cooler 100k0546010906 Upper Gasket Kit 100k0546010907 Lower Gasket Kit 100k054601060301 Air Cleaner [a] 100k054601060302 Air Cleaner [ca] 100k0546010604 Air Cleaner [component Parts] 100k0546010607 Muffler 100k0546010612 Intercooler 100k054601a010 Hand Accelerator Lever 100k054601a030 Accelerator Pedal 100k054601a060 Engine Stop Wire 100k0546fuel System 01a120 Fuel Tank Rh 100k054601a130 Fuel Tank Lh 100k054601a140 Fuel Pipe 100k054601a151 Separator 100k054601a161 Separator [component Parts] 100k0546cooling Water System 01a41002 Fan 100k054601a420 Water Pipe 100k054601a43002 Radiator 100k054601a450 Reserve Tank 100k0546electrical System 01a54001 Alternator [a] 100k054601a54002 Alternator [ca] 100k054601a55001 Alternator [component Parts][a]100k054601a55002 Alternator [component Parts][ca]100k054601a560 Starter 100k0546
