Item Part No. Description Book Engine 010001 Crankcase 100k0485010002 Oil Pan 100k0485010003 Cylinder Head 100k0485010004 Gear Case 100k0485010005 Head Cover [old Type] 100k048501000501 Head Cover [new Type] 100k0485010101 Camshaft And Idle Gear Shaft 100k0485010102 Piston And Crankshaft 100k0485010103 Flywheel 100k0485010106 Balancer 100k0485010202 Injection Pump 100k0485010204 Governor 100k0485010206 Nozzle Holder And Glow Plug 100k0485010207 Nozzle Holder [component Parts] 100k0485010209 Pump Housing 100k0485010212 Fork Lever (Governor) 100k0485010215 Governor Adjusting Bolt 100k0485010300 Fuel Filter 100k0485010500 Water Flange And Thermostat 100k0485010501 Water Pump 100k0485010600 Valve And Rocker Arm 100k0485010601 Inlet Manifold 100k0485010602 Exhaust Manifold 100k0485010603 Air Cleaner 100k0485010604 Air Cleaner [component Parts] 100k048501060702 Under Muffler 100k048501060802 Turbo Charger 100k0485010610 Actuator 100k0485010611 Oil Pipe(Turbo Charger) 100k0485010612 Intercooler 100k048501070202 Hydraulic Pump Base [a] 100k0485010705 Oil Cooler 100k0485010906 Upper Gasket Kit [old Type] 100k048501090601 Upper Gasket Kit [new Type] 100k0485010907 Lower Gasket Kit 100k048501a01002 Hand Accelerator Lever 100k048501a060 Engine Stop Wire 100k0485fuel System 01a120 Fuel Tank Rh 100k048501a130 Fuel Tank Lh 100k048501a140 Fuel Pipe 100k048501a151 Separator 100k048501a161 Separator [component Parts] 100k0485cooling Water System 01a410 Fan 100k048501a420 Water Pipe 100k048501a43002 Radiator 100k048501a450 Reserve Tank 100k0485electrical System 01a540 Alternator 100k048501a550 Alternator [component Parts] 100k048501a560 Starter 100k048501a570 Starter [component Parts] 100k048501a580 Battery 100k048501b110 Switch 100k048501b140 Panel Board 100k048501b150 Panel Board [component Parts] 100k048501b320 Light 100k048501b33503 Hazard Light/tail Light 100k048501b51002 Electrical Wiring 100k0485transmission/clutch/rear Axle 01c11002 Clutch Housing 100k048501c115 Bearing Holder 100k0485
