Item Part No. Description Book Engine 01000101 Crankcase [old Type] 100k073801000102 Crankcase [new Type] 100k073801000202 Oil Pan 100k073801000301 Cylinder Head [old Type] 100k073801000302 Cylinder Head [new Type] 100k073801000401 Gear Case [old Type] 100k073801000402 Gear Case [new Type] 100k0738010005 Head Cover 100k0738010008 Oil Pump 100k0738010009 Fuel Pump Base 100k073801001001 Breather [old Type] 100k073801001002 Breather [new Type] 100k0738010011 Relief Valve 100k0738010100 Main Bearing Case 100k0738010101 Camshaft And Idle Gear Shaft 100k073801010201 Piston And Crankshaft [oldtype]100k073801010202 Piston And Crankshaft [newtype]100k0738010103 Flywheel 100k073801020201 Injection Pump [old Type] 100k073801020202 Injection Pump [new Type] 100k073801020301 Injection Pump [componentparts] [old Type]100k073801020302 Injection Pump [componentparts] [new Type]100k073801020601 Nozzle Holder And Glow Plug[old Type]100k073801020602 Nozzle Holder And Glow Plug[new Type]100k0738010207 Nozzle Holder [componentparts] [old Type]100k0738010210 Fuel Control Motor 100k073801030001 Fuel Filter [old Type] 100k073801030002 Fuel Filter [new Type] 100k0738010305 Fuel Filter [component Parts] 100k0738010500 Water Flange And Thermostat 100k0738010501 Water Pump 100k0738010600 Valve And Rocker Arm 100k0738010601 Inlet Manifold 100k0738010602 Exhaust Manifold 100k0738010608 Turbo Charger 100k0738010609 Turbo Charger [componentparts]100k0738010611 Oil Pipe (Turbo Charger) 100k0738010702 Hydraulic Pump Base 100k073801090601 Upper Gasket Kit [old Type] 100k073801090602 Upper Gasket Kit [new Type] 100k073801090701 Lower Gasket Kit [old Type] 100k073801090702 Lower Gasket Kit [new Type] 100k0738010603 Air Cleaner 100k0738010604 Air Cleaner [component Parts] 100k0738010606 Inlet Pipe 100k0738
