Item Part No. Description Book Engine 010001 Crankcase 100k0760010002 Oil Pan 100k0760010003 Cylinder Head 100k0760010004 Gear Case 100k0760010005 Head Cover 100k0760010101 Camshaft And Idle Gear Shaft 100k0760010102 Piston And Crankshaft 100k0760010103 Flywheel 100k0760010106 Balancer 100k0760010202 Injection Pump 100k0760010204 Governor 100k0760010206 Nozzle Holder And Glow Plug 100k0760010207 Nozzle Holder [component Parts] 100k0760010209 Pump Housing 100k0760010212 Fork Lever (Governor) 100k0760010215 Governor Adjusting Bolt [oldtype]100k076001021501 Governor Adjusting Bolt [newtype]100k0760010300 Fuel Filter 100k0760010500 Water Flange And Thermostat 100k0760010501 Water Pump 100k0760010600 Valve And Rocker Arm 100k0760010601 Inlet Manifold 100k0760010602 Exhaust Manifold 100k076001060301 Air Cleaner [a] 100k0760010604 Air Cleaner [component Parts] 100k0760010607 Muffler 100k076001060802 Turbo Charger 100k0760010610 Actuator 100k0760010611 Oil Pipe (Turbo Charger) 100k0760010612 Intercooler 100k076001070202 Hydraulic Pump Base [exceptm8200hdc]100k0760010705 Oil Cooler 100k0760010906 Upper Gasket Kit 100k0760010907 Lower Gasket Kit 100k076001a010 Hand Accelerator Lever 100k076001a030 Accelerator Pedal 100k076001a060 Engine Stop Wire 100k0760fuel System 01a120 Fuel Tank Rh 100k076001a130 Fuel Tank Lh 100k076001a140 Fuel Pipe 100k076001a151 Separator 100k076001a161 Separator [component Parts] 100k0760cooling Water System 01a41002 Fan 100k076001a420 Water Pipe 100k076001a43002 Radiator 100k076001a450 Reserve Tank 100k0760electrical System 01a54001 Alternator [a] 100k076001a55001 Alternator [component Parts] [a] 100k076001a560 Starter 100k076001a570 Starter [component Parts] 100k076001a58001 Battery [old Type] 100k076001a58002 Battery [new Type] 100k076001b015 Switch/sensor 100k076001b105 Switch (Panel Board) 100k076001b11001 Switch (Wiper/work Light) [a] [oldtype]100k0760
