Kubota L2350DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k038301t002 Oil Pan 100k038301t003 Piston And Crankshaft 100k038301t004 Main Bearing Case 100k038301t005 Flywheel 100k038301t006 Cylinder Head 100k038301t007 Valve And Rocker Arm 100k038301t008 Nozzle Holder Andglow Plug100k038301t009 Nozzle Holder[component Parets]100k038301t010 Cylinder Head Cover 100k038301t011 Inlet Manifold 100k038301t016 Camshaft 100k038301t017 Gear Case 100k038301t018 Water Pump 100k038301t019 Water Flange Andthermostat100k038301t020 Injection Pump And Fuelcamshaft100k038301t021 Injection Pump[component Parts]100k038301t022 Speed Control Plate 100k038301t023 Governor 100k038301t024 Upper Gasket Kit 100k038301t025 Lower Gasket Kit 100k038302t012 Air Cleaner 100k038302t013 Air Cleaner[component Parts]100k038302t014 Exhaust Manifold 100k038302t01501 Muffler 100k038302t01502 Under Muffler [oldtype] [option]100k038302t01503 Under Muffler [newtype] [option]100k038302t026 Hand Acceleratorlever100k0383fuel System 02t02702 Fuel Tank 100k038302t028 Fuel Filter And Fuel Pipe 100k0383cooling Water System 02t029 Water Pipe 100k038302t030 Radiator 100k038302t031 Shutter 100k0383electrical System 02t032 Dynamo And Fan 100k038302t033 Dynamo [componentparts]100k038302t034 Starter 100k038302t035 Starter [componentparts]100k038302t036 Battery 100k038302t037 Switch 100k038302t03801 Light [oil Type] 100k038302t03802 Light [new Type] 100k038302t03902 Regulator And Meter 100k038302t04003 Electrical Wiring [oldtype]100k0383​
