Item Part No. Description Book Engine 01000101 Crankcase 100k079801000102 Crankcase 100k0798010002 Oil Pan 100k0798010003 Cylinder Head 100k0798010004 Gear Case 100k079801000501 Head Cover 100k079801000502 Head Cover 100k0798010006 Oil Filter 100k0798010007 Dipstick And Guide 100k0798010100 Main Bearing Case 100k0798010101 Camshaft And Idle Gear Shaft 100k0798010102 Piston And Crankshaft 100k0798010103 Flywheel 100k0798010105 Fuel Camshaft And Governorshaft100k0798010200 Idle Apparatus 100k0798010202 Injection Pump 100k079801020401 Governor 100k079801020402 Governor 100k0798010205 Speed Control Plate 100k079801020601 Nozzle Holder And Glow Plug 100k079801020602 Nozzle Holder And Glow Plug 100k079801020701 Nozzle Holder [componentparts]100k079801020702 Nozzle Holder [componentparts]100k0798010301 Fuel Pump(Mechanical) 100k0798010500 Water Flange Andthermostat100k0798010501 Water Pump 100k0798010600 Valve And Rocker Arm 100k079801060101 Inlet Manifold 100k079801060102 Inlet Manifold 100k0798010602 Exhaust Manifold 100k0798010603 Air Cleaner 100k0798010605 Muffler 100k0798010900 Upper Gasket Kit 100k0798010901 Lower Gasket Kit 100k079801a00101 Accelerator Lever 100k0798fuel System 01a101 Fuel Tank 100k079801a11001 Fuel Pipe 100k079801a11002 Fuel Pipe 100k079801a11003 Fuel Pipe 100k079801a13001 Fuel Filter [componentparts]100k079801a13002 Fuel Filter [componentparts]100k0798cooling Water System 01a40101 Fan 100k079801a40102 Fan 100k079801a410 Water Pipe 100k079801a42001 Radiator [except [au]] 100k079801a42002 Radiator [au] 100k079801a430 Reserve Tank 100k0798electrical System 01a51001 Stop Solenoid 100k079801a51002 Stop Solenoid 100k079801a521 Dynamo 100k079801a523 Dynamo [component Parts] 100k079801a525 Starter 100k079801a530 Starter [component Parts] 100k0798
