Item Part No. Description Book Engine 010001 Crankcase 100k0772010002 Oil Pan 100k0772010003 Cylinder Head 100k0772010004 Gear Case 100k0772010005 Head Cover 100k0772010006 Oil Filter 100k0772010007 Dipstick And Guide 100k0772010100 Main Bearing Case 100k0772010101 Camshaft And Idle Gear Shaft 100k0772010102 Piston And Crankshaft 100k0772010103 Flywheel 100k0772010105 Fuel Camshaft And Governorshaft100k0772010200 Idle Apparatus 100k0772010202 Injection Pump 100k0772010204 Governor 100k077201020401 Governor 100k0772010205 Speed Control Plate 100k0772010206 Nozzle Holder And Glow Plug 100k0772010207 Nozzle Holder [componentparts]100k0772010301 Fuel Pump(Mechanical) 100k0772010500 Water Flange Andthermostat100k0772010501 Water Pump 100k0772010600 Valve And Rocker Arm 100k0772010601 Inlet Manifold 100k0772010602 Exhaust Manifold 100k0772010603 Air Cleaner 100k0772010605 Muffler 100k0772010900 Upper Gasket Kit [option] 100k077201090001 Upper Gasket Kit 100k0772010901 Lower Gasket Kit 100k077201a001 Accelerator Lever 100k0772fuel System 01a101 Fuel Tank 100k077201a110 Fuel Pipe 100k077201a130 Fuel Filter [componentparts]100k0772cooling Water System 01a401 Fan 100k077201a410 Water Pipe 100k077201a42001 Radiator [a] [ca] 100k077201a42002 Radiator [au] [nz] 100k077201a430 Reserve Tank 100k0772electrical System 01a510 Stop Solenoid 100k077201a521 Dynamo 100k077201a523 Dynamo [component Parts] 100k077201a525 Starter 100k077201a530 Starter [component Parts] 100k077201a535 Battery 100k077201b101 Switch 100k077201b115 Panel Board 100k077201b120 Panel Board [componentparts]100k077201b301 Head Right 100k077201b302 Hazard Light 100k077201b304 Tail Light 100k077201b310 Winker Lamp 100k077201b501 Electrical Wiring [a] [ca] 100k077201b50101 Electrical Wiring [au] [nz] 100k0772
