Item Part No. Description Book Engine 010001 Crankcase 100k0780010002 Oil Pan 100k0780010003 Cylinder Head 100k0780010004 Gear Case 100k0780010005 Head Cover 100k0780010006 Oil Filter 100k0780010007 Dipstick And Guide 100k0780010100 Main Bearing Case 100k0780010101 Camshaft And Idle Gear Shaft 100k0780010102 Piston And Crankshaft 100k0780010103 Flywheel 100k0780010105 Fuel Camshaft And Governorshaft100k0780010200 Idle Apparatus 100k0780010202 Injection Pump 100k0780010204 Governor 100k078001020401 Governor 100k0780010205 Speed Control Plate 100k0780010206 Nozzle Holder And Glow Plug 100k0780010207 Nozzle Holder [componentparts]100k0780010301 Fuel Pump(Mechanical) 100k0780010500 Water Flange Andthermostat100k0780010501 Water Pump 100k0780010600 Valve And Rocker Arm 100k0780010601 Inlet Manifold 100k0780010602 Exhaust Manifold 100k0780020603 Air Cleaner 100k0780020605 Muffler 100k0780010900 Upper Gasket Kit [option] 100k0780010901 Lower Gasket Kit [option] 100k078002a00102 Accelerator Lever 100k0780fuel System 02a101 Fuel Tank 100k078002a110 Fuel Pipe 100k078002a130 Fuel Filter [componentparts]100k0780cooling Water System 02a401 Fan 100k078002a410 Water Pipe 100k078002a42001 Radiator [a] [ca] 100k078002a42002 Radiator [except [a] [ca]] 100k078002a430 Reserve Tank 100k0780electrical System 02a51001 Stop Solenoid 100k078001a521 Dynamo 100k078001a523 Dynamo [component Parts] 100k078002a525 Starter 100k078002a530 Starter [component Parts] 100k078002a535 Battery 100k078002b10102 Switch 100k078002b11501 Panel Board 100k078002b120 Panel Board [componentparts]100k078002b301 Head Right 100k078002b302 Hazard Light 100k078002b30401 Tail Light 100k078002b310 Winker Lamp 100k078002b50102 Electrical Wiring 100k078002b50103 Electrical Wiring [a] [ca] 100k078002b50104 Electrical Wiring [au] [nz] 100k0780
