Item Part No. Description Book Engine 010001 Crankcase 100k081301000101 Crankcase 100k0813010002 Oil Pan 100k0813010003 Cylinder Head 100k0813010004 Gear Case 100k0813010005 Head Cover 100k081301000501 Head Cover 100k0813010006 Oil Filter 100k0813010100 Main Bearing Case 100k0813010101 Camshaft And Idle Gearshaft100k0813010102 Piston And Crankshaft 100k0813010103 Flywheel 100k0813010105 Fuel Camshaft Andgovernor Shaft100k081301020001 Idle Apparatus 100k081301020002 Idle Apparatus 100k0813010202 Injection Pump 100k081301020401 Governor 100k081301020402 Governor 100k081301020403 Governor 100k0813010205 Speed Control Plate 100k0813010206 Nozzle Holder And Glowplug100k081301020601 Nozzle Holder And Glowplug100k0813010207 Nozzle Holder [componentparts]100k081301020701 Nozzle Holder [componentparts]100k0813010301 Fuel Pump(Mechanical) 100k0813010500 Water Flange Andthermostat100k0813010501 Water Pump 100k0813010600 Valve And Rocker Arm 100k0813010601 Inlet Manifold 100k081301060101 Inlet Manifold 100k0813010602 Exhaust Manifold 100k0813010603 Air Cleaner 100k0813010605 Muffler 100k0813010900 Upper Gasket Kit 100k081301090001 Upper Gasket Kit 100k0813010901 Lower Gasket Kit 100k081301090101 Lower Gasket Kit 100k081301a001 Accelerator Lever 100k0813fuel System 01a101 Fuel Tank 100k081301a11001 Fuel Pipe 100k081301a11002 Fuel Pipe 100k081301a130 Fuel Filter [componentparts]100k0813cooling Water System 01a401 Fan 100k081301a410 Water Pipe 100k081301a42001 Radiator [except [au]] 100k0813
