Item Part No. Description Book Frequently Used Items 00000003 Frequently Used Items 100k0929engine 021001 Crankcase 100k0929021002 Oil Pan 100k0929021003 Cylinder Head 100k0929021004 Gear Case 100k0929021005 Head Cover 100k0929021006 Oil Filter 100k0929021007 Dipstick And Guide 100k0929021008 Oil Pump 100k0929021100 Main Bearing Case 100k0929021101 Camshaft And Idle Gearshaft100k0929021102 Piston And Crankshaft 100k0929021103 Flywheel 100k0929021105 Fuel Camshaft Andgovernor Shaft100k0929021200 Idle Apparatus 100k0929021201 Stop Solenoid 100k0929021202 Injection Pump 100k0929021204 Governor 100k0929021205 Speed Control Plate 100k0929021206 Nozzle Holder And Glowplug100k0929021207 Nozzle Holder [componentparts]100k0929021305 Cover 100k0929021402 Alternator And Pulley 100k0929021403 Alternator [componentparts]100k0929021404 Starter 100k0929021405 Starter [component Parts] 100k0929021406 Oil Switch/thermometer 100k0929021500 Water Flange Andthermostat100k0929021501 Water Pump 100k0929021504 Fan 100k0929021600 Valve And Rocker Arm 100k0929021601 Inlet Manifold 100k0929021602 Exhaust Manifold 100k0929031603 Air Cleaner 100k092903160502 Muffler 100k0929021900 Upper Gasket Kit 100k0929021901 Lower Gasket Kit 100k0929021908 Piston Kit 100k092903a001 Accelerator Lever 100k0929fuel System 03a101 Fuel Tank 100k092903a110 Fuel Pipe 100k0929cooling Water System 03a410 Water Pipe 100k092903a420 Radiator 100k0929electrical System 03a53502 Battery 100k092903b11502 Panel Board 100k092903b21502 Switch/sensor 100k092903b301 Head Light 100k0929
