Item Part No. Description Book Engine 01t001 Crankcase 100k036001t00201 Oil Pan (2wd) 100k036001t00202 Oil Pan (4wd) 100k036001t003 Piston And Crankshaft 100k036001t004 Main Bearing Case 100k036001t005 Flywheel 100k036001t006 Cylinder Head 100k036001t007 Valve And Rocker Arm 100k036001t008 Nozzle Holder And Fuel Pipe 100k036001t009 Nozzle Holder [component Parts] 100k036001t010 Cylinder Head Cover 100k036001t011 Inlet Manifold 100k036001t012 Air Cleaner (Double) 100k036001t013 Air Cleaner (Double) [componentparts]100k036001t014 Air Cleaner Support 100k036001t015 Pre-cleaner [option] 100k036001t016 Muffler And Exhaust Manifold 100k036001t017 Under Muffler [option] 100k036001t018 Camshaft 100k036001t019 Gear Case 100k036001t020 Oil Filter [component Parts] 100k036001t021 Water Flange And Thermostat 100k036001t022 Water Pump 100k036001t023 Fuel Camshaft 100k036001t024 Injection Pump 100k036001t025 Injection Pump [component Parts] 100k036001t026 Engine Stop Lever 100k036001t027 Speed Control Plate 100k036001t028 Governor 100k036001t057 Hand Accelerator 100k036001t05801 Accelerator Pedal 100k036001t05901 Engine Stop Rod 100k0360fuel System 01t060 Fuel Tank 100k036001t061 Fuel Tank Support 100k036001t06201 Fuel Pipe 100k036001t063 Fuel Filter [component Parts] 100k0360cooling Water System 01t06401 Radiator 100k036001t06501 Water Pipe 100k0360electrical System 01t066 Starter 100k036001t067 Dynamo And Fan 100k036001t06901 Starter [component Parts] 100k036001t07001 Dynamo [component Parts] 100k036001t07101 Battery 100k036001t072 Panel Board 100k036001t073 Panel Board [component Parts] 100k036001t074 Switch 1 100k036001t075 Light 1 100k036001t076 Light 2 100k036001t077 Working Light And Trailer Harness[option]100k036001t078 Wire Harness 100k0360clutch 01t079 Clutch 100k036001t080 Clutch Fork 100k036001t081 Clutch Pedal 100k036001t082 Pto Clutch Fork 100k036001t083 Pto Clutch Lever 100k0360
