Item Part No. Description Book Engine 010001 Crankcase 100k0632010002 Oil Pan 100k0632010003 Cylinder Head 100k0632010004 Gear Case 100k0632010005 Head Cover [old Type] 100k063201000501 Head Cover [new Type] 100k0632010100 Main Bearing Case 100k0632010101 Camshaft And Idle Gear Shaft 100k0632010102 Piston And Crankshaft 100k0632010103 Flywheel 100k0632010105 Fuel Camshaft 100k0632010106 Balancer 100k0632010200 Engine Stop Lever 100k0632010202 Injection Pump 100k0632010204 Governor 100k0632010205 Speed Control Plate 100k0632010206 Nozzle Holder And Glow Plug 100k0632010207 Nozzle Holder [component Parts] 100k0632010500 Water Flange And Thermostat 100k0632010501 Water Pump 100k0632010600 Valve And Rocker Arm 100k0632010601 Inlet Manifold 100k0632010603 Exhaust Manifold/muffler 100k0632010604 Air Cleaner 100k0632010901 Upper Gasket Kit 100k0632010902 Lower Gasket Kit 100k063201a010 Accelerator Lever 100k0632fuel System 01a101 Fuel Tank 100k063201a110 Fuel Pipe 100k063201a120 Fuel Filter 100k063201a130 Fuel Filter [component Parts] 100k0632cooling Water System 01a401 Fan 100k063201a410 Water Pipe 100k063201a420 Radiator 100k063201a430 Reserve Tank 100k0632electrical System 01a515 Alternator 100k063201a520 Alternator [component Parts] 100k063201a525 Starter 100k063201a530 Starter [component Parts] 100k063201a535 Battery 100k063201b102 Switch 1 [old Type] 100k063201b10201 Switch 1 [new Type] 100k063201b103 Switch 2 100k063201b104 Switch 3 100k063201b115 Panel Board 100k063201b120 Panel Board [component Parts] 100k063201b303 Head Light 100k063201b311 Hazard Light 100k063201b312 Tail Light [old Type] 100k063201b31201 Rear Lamp [new Type] 100k063201b503 Electrical Wiring (Front) [old Type] 100k063201b50301 Electrical Wiring (Front) [new Type] 100k0632
